Old 04-15-2015, 05:05 PM   #15
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
Originally Posted by So Cal Camaro View Post
If 3mm makes that big a difference, you're the dumbass for buying wheels with the wrong offset.
Why are you even commenting here? "Dumbass"
You are stupid if you think i should put a 3mm spacer to fix my issue. The tire hits already lets just put a peice of metal between my rim and rotor so it sticks past the fender completely? Retard go home.
revived is offline   Reply With Quote
Old 04-15-2015, 05:08 PM   #16
revived
Vrrrm.
revived's Avatar
Originally Posted by JimE View Post
Hence his numerous requests for a tire brand/size that is not as wide.
Thank you, you have renewed my faith in humanity
Old 04-15-2015, 05:48 PM   #17
revived
Vrrrm.
revived's Avatar
Boze helped me out, when measuring a wheel i guess you measure from lip to lip then deduct a inch? i measured mine to be 11outer lip, inner lip 10.5 so these are techincally a 10 wheel. Makes sense now.
Boze doesnt give offsets? just back space and i found this and called and zack verified it for me.
Front wheels: 20x8.5, 5.75-inch BS, 255/45-20 tire
Rear Wheels: 20x10, 6.875-inch BS, 285/40-20 tire
Read more: http://www.superchevy.com/how-to/cam...#ixzz3XQ9TcX3l
Follow us: @SuperChevy on Twitter | SuperChevyMag on Facebook
Old 04-15-2015, 06:15 PM   #18
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
What offset are your wheels and where is it rubbing?
Best regards,
Tyler
888-308-6007
Old 04-15-2015, 06:38 PM   #19
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
I don`t know how many miles you have on your car but have you checked your rear struts? If they are fine then maybe you might want to consider changing to a little stiffer strut before buying another set of tires.
mickss is offline   Reply With Quote
Old 04-15-2015, 07:25 PM   #20
revived
Vrrrm.
revived's Avatar
I figured it out, thanks
Old 04-15-2015, 07:33 PM   #21
revived
Vrrrm.
revived's Avatar
Best regards,
Tyler
888-308-6007
After alot of research about boze and calling them today. I learned.
boze wont give there offsets out, lets just say they are not 35.
The rear wheel is 10 inch (but measured 11 outer to outer lip) and they recommend a 285 out back, which makes sense. There offsets are built around that tire size not 315.
Thanks though if you dont mind if i order new wheels whats it the absolute widest i can get can anyone make a 345 fit?
Old 04-15-2015, 08:46 PM   #22
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
had 315s on for over 2 years. never once rubbed. who speced the offset of your rear wheels?
the Nittos are very narrow tires any others brand 305s will rub just as bad if your offset is that screwed up.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 04-15-2015, 09:02 PM   #23
revived
Vrrrm.
revived's Avatar
Well, boze designed the offset for a 285 tire is all.
10 inch wheel really is too skinny for a 315 anyway, so again i am allset i figured it out.
