03-21-2016, 10:16 AM | #15 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
Wasn't sure if the pump would support the minimal flow/pressure required by the injector if there were such a requirement to be tuned properly. I don't know enough to make an appropriate judgement call. It looks like I will be ordering my new 1000's and selling off my 850's after only 400 miles -__-. HA!
03-21-2016, 11:02 AM | #16 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
The ZL1 pump is setup to run on E85 whoever says it's not is incorrect, it just will not feed as high of hp level you are looking for.
03-21-2016, 11:48 AM | #17 |
If you haven't purchased the ID1000's do yourself a favor and get the new ID1300's, the 1000's are pretty much done at 800rwhp on E85 for PD Blower with dual pumps (Turbo might be different story), the 1300's will leave you some room to grow, I just upgraded mine from ID1000's to ID13000's, they didn't have the 1300's when I did mine a few years ago.
03-21-2016, 12:09 PM | #18 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
What dual pump setup are you looking at Devin? Unreal, has been helping me out on the Fore system I've been looking at.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
03-21-2016, 12:11 PM | #19 | |
03-21-2016, 12:38 PM | #20 |
ID1000s will max out a TVS on e85, and are cheaper. If he ever wants to go bigger later I get the recommendation for 1300s but you can grab 1000s for a lot less.
Nick
Corvette Z06 -1200ish rwhp |
03-21-2016, 03:39 PM | #21 |
They didn't max out mine, 803rwhp on my TVS2300 13 psi and 1000 injectors were coming up short on E74 let alone E85, needed to go to 1300 per JRE so I did, new tune will yield more when complete.
03-21-2016, 06:37 PM | #22 |
Probably could have just bumped fuel pressure. I had no issue making 1000rwhp on ID1000s on e85. Base pressure was ~60psi though.
Maybe they won't be enough if you ran 43-45psi, but should have no issues at higher pressure.
Nick
03-21-2016, 09:11 PM | #23 | |
The 1300's are rated at 1200 crank hp on E85, interesting you were able to almost make that at the wheels with 1000's which are rated around 1000 crank, you have it figured out for sure, wish I could have and didn't have to spend the upgrade money. |
