07-02-2013, 12:26 AM | #15 |
SparkyDL75
I have full Pedders suspension in the rear and am wondering if this setup would fit. The car is lowered 0.5" with the Xa Coilovers. I have ZL1 lower control arms and the Pedders ZL1 rear sway bar. My 20x10 +38 offset wheel doesn't leave a lot of room between the wheel and sway bar.
2010 CGM 2SS/RS M6 LS3 Black/Gray
Exterior American Racing BLVD Black w/Machined(20x10) Mickey Thompson Street Comps(275/40 & 305/35) Suspension Pedders Pace Car Pkg w/ZL1 Upgrade; Pedders Upper & Lower Control Arm, Steering, & Differential Mount Bushings; Pedders SS Brake Lines; Pedders Dual Bearing Camber Plates; ZL1 Toe Link; Hawk Performance Ceramic brake pads Drivetrain Maggie2300(8psi-3.4pulley); CompCam; 85lb injectors; ZL1 fuel pump; ZR1 MAP; Centerforce DYAD Twin Disc clutch; Stainless Works LT headers; QTP Cutouts; Rotofab intake; RX catch can; Mike Norris tune 643rwhp 598 rwtq |
07-02-2013, 01:44 AM | #16 | |
Drives: 2010 SS RS Join Date: Apr 2009
Pete said ver2 z-bar and now ver3 is about 8mm more narrow on each side. With that said, you take your chances. Car fully loaded or full suspension travel and tire will probably scrape. Not even thinking about your ver of z-bar. I am skeptical because I tried pedder's z-bar and now own pfadt's z-spec bar. I didn't want to chance the newer ver z-bar scraping based on 8mm on each side. If they are willing to fully refund, try it out. Pete took care of me when the z-bar scraped my CCWs. But my rims came first, sways came later. From an autox standpoint, understeers is an issue. I run 20x10 and 20x11.5. Never thought I would get serious with autox, but in hindsight, I would go squared wheels. Or, street and track setups. Prioritize your goals. Good luck. |
07-02-2013, 09:05 AM | #17 |
im running 315 nittos on an 10" wheel. what would be the point of a 12" wheel? i know they say the Invos run small....but 2" small? idk about that.
07-02-2013, 03:38 PM | #18 |
Drives: 2017 ZL1 Join Date: Dec 2009
Dropped on pedders Xa coils about 1.5 rear with negative 1.1 degrees of camber. Wheels are D2FORGED MB-08 20x12
Elite Design Concepts NY5THGEN2017 ZL1 Garnet Red/M6/// IG @Crazl1
Tags |
camaro 20x12 wheels, deep concave 20x12 |
