#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > I4 Turbo LTG Engine, Exhaust, and Bolt-Ons
Old 08-30-2017, 09:43 AM   #15
Beast-Y-Blue
Drives: Hyper Blue 2016 Camaro turbo
Beast-Y-Blue is offline   Reply With Quote
Old 08-30-2017, 10:06 AM   #16
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Looks great! Nice job!
Jason@JacFab is offline   Reply With Quote
Old 08-30-2017, 11:35 AM   #17
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
WOW. Awesome fabrication OP!!! Very clean!
soloknight6 is offline   Reply With Quote
Old 08-30-2017, 12:01 PM   #18
Beast-Y-Blue
Originally Posted by whiskeyfed View Post
Looks good man! How is it handling the heat? noticing any better or worse performance?
Closed box set up handle heat very well but you lose the turbo sound.
Prior to making this open box set up i used the filter alone and remove the box. Well it sounded great but I noticed that temp would go up very fast in traffic stop and go type situations. That why i decided to mimic my own version of GM 's insulated open box setup. I made sure to perfectly seal off the hot air from engine compartment. Needless to say i do not have any issue with temps going up at stop an go traffic anymore and getting similar performance as the closed box set up but with the turbo noise which was my main reason for this project at the first place..
Old 08-30-2017, 12:54 PM   #19
Beast-Y-Blue
Coming from youJason , means alot thanks
Old 08-30-2017, 12:56 PM   #20
Beast-Y-Blue
Thank you sir
Old 08-30-2017, 01:09 PM   #21
whiskeyfed
Pat
whiskeyfed's Avatar
Drives: 2017 Camaro 1LT I4 Turbo A8
Prior to making this open box set up i used the filter alone and remove the box. Well it sounded great but I noticed that temp would go up very fast in traffic stop and go type situations. That why i decided to mimic my own version of GM 's insulsted open box set. I made sure to perfectly seal off the hot air from engine compartment. Needless to say i do not have any issue with temps going up at stop an go traffic anymore and getting similar performance as the closed box set up but with the turbo noise which was my main reason for this project at the first place..
Nice man! good for you! I wish I had the time and the expertise to make one myself. I wonder if Injen would sell just the open box containment unit. I really loved just the filter too but you're right. My temps went up in stop and go too.
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro
Follow my Build Thread The WhiskeyFed Camaro
Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket
DYNO SHEET: 297whp / 374wtq
Tuned by #danytechtuning
whiskeyfed is offline   Reply With Quote
Old 08-30-2017, 02:29 PM   #22
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
Nice job man! Another way to go at this might be purchasing the Mishimoto intake tube and going from there (was considering this myself)
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Corner carver is offline   Reply With Quote
Old 08-30-2017, 02:30 PM   #23
Corner carver
Post us a pic of it lit up!
Old 08-30-2017, 03:26 PM   #24
Beast-Y-Blue
If you have IG go to the original post, the first instagram link has a short video of it lit up. I will post a pic of it later when i get a chance.
Old 08-30-2017, 04:41 PM   #25
6th_gen_gino
Drives: 2016 camaro 2.0t gray
Dude it looks amazing !!!!
6th_gen_gino is offline   Reply With Quote
Old 08-30-2017, 05:19 PM   #26
Beast-Y-Blue
Pic of box with LED on
Old 08-30-2017, 05:20 PM   #27
Beast-Y-Blue
Thank you my friend
Old 08-30-2017, 06:00 PM   #28
SoCalThug
Drives: 2012 Summit White 1Ls
looks awsome but im curious as to why you didnt just cut off the top of the original injen box and leave the rest?
SoCalThug is offline   Reply With Quote
