12-14-2023, 01:04 PM | #15 | |
2014 ZL1, 2015 GMC, 2003 Goldwing,
12-14-2023, 01:19 PM | #16 |
Ok, Getting rid of the gap at the bypass by having it adjusted tighter is a known mod that I think everyone here has done. You will reach a point in your boost where it'll run like crap and threasholds will need adjusted. Listen to GTSTOREY, he doesn't know it, but has helped me several times on the HPTuners forum and knows his poo.
Attached is a link to my video I did where max boost was messing with me and what I had to do to fix it. This is an older video and more has been learned and minor corrections to the video are in order, but I think you'll get the jist. Not sure if this is what you're talking about but here it is anyways. https://youtu.be/2Y7rPBwQMWg?si=--YyF4X-H5UH0gfJ . . . . . . Mark
12-14-2023, 01:34 PM | #17 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
Yeah ok you should have went with the potato
I won't win the forum's most polite member award this year so keep that in mind with my response. I don't think you understand this engines controllers as much as you would like to. First the codes to throw a CEL or limp home won't self tune the car or keep it from harm quickly as it could or you are thinking. Why am I so stupid to pay JRE like $500 for a mail order tune Second I don't think you understand that controller. It doesn't shut down like a blowoff valve or built in turbo controller blade (with stock pullies unless some big problem/boost disable). It's there to use less hp spinning the rotors during non boost. They had it to shut tighter but in cold weather it'd get stuck shut so they made it gap some like throttle blades in a carb at idle. Not completely shut. If you made it shut more you might get 1psi unless it was far out of adjustment. If you think you have 15psi now you have already melted your cats from your unknown mods. Congrats |
12-14-2023, 01:44 PM | #18 | |
12-14-2023, 02:20 PM | #19 |
Big Crow
12-14-2023, 02:28 PM | #20 |
If you don’t understand what I have done, it’s ok, I knew not everyone would see and understand it. All I’ve done is change the spring ratio of the bypass actuator, nothing else. A little math on the spring rates is all.
12-14-2023, 03:19 PM | #21 |
Big Crow
Oh I did think it looked like that. Treating it just like a blowoff valve actuator....
12-14-2023, 03:44 PM | #22 |
Drives: 2013 ZL1 Join Date: Sep 2021
I guess I am trying to understand how you got 3lbs of boost by playing with the actuator unless it was way out of adjustment? Like has been said before it really has nothing to do with increasing boost when properly adjusted. The factory gauge is not that accurate so I wouldn't trust it for values . When you increase boost too much you increase cylinder pressure which can lead to detonation unless you make adjustments to fuel and timing to compensate. Stock boost is 8.5-9 psi if for some reason you really are at 12 psi I would say your already in the danger zone.
12-14-2023, 03:48 PM | #23 |
Yes, if the supercharger or turbocharger is already making more than can be used, and needs to be vented, why spin them faster to do the same thing? Unless the cfm volume is not enough per displacement of the engine at said psi, aka out of lungs. Now I admit I may need to tune and I’m scheduling a dyno run and ordering hp tuner soon.
12-14-2023, 03:55 PM | #24 | |
12-14-2023, 03:56 PM | #25 | |
12-14-2023, 04:23 PM | #26 | |
12-14-2023, 04:29 PM | #27 | |
12-14-2023, 04:58 PM | #28 | |
Drives: 2013 ZL1 Join Date: Nov 2018
I was just telling you that 540 wheel in cool air is about the limit of the stock injectors with a manual trans. Do I think you're making 540 wheel? No, if that's the only mod you did. It will be around 510 wheel with an auto. I can tell you this, what you have done has changed the power curve which will inherently effect the transmission as the transmission programming is not made for that power that early if it's an automatic..
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
