10-31-2018, 02:06 PM | #15 |
BLEW BIU
Drives: 2018 2SS 1LE Hyper Blue Join Date: Oct 2017
10-31-2018, 02:16 PM | #16 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
Hardly heaven. Cost an extra $100.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
10-31-2018, 02:32 PM | #17 |
BLEW BIU
10-31-2018, 04:31 PM | #18 |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
I wish I could get lifetime free alignments. I'd be in there every 6 months. More so early on as I would be testing settings for tire wear. I'd be happy to pay the extra $100 for that service.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
10-31-2018, 04:35 PM | #19 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Wheel Works offered a lifetime alignment service.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
10-31-2018, 08:15 PM | #20 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
I'll save you the time.. max front about -2.4 front -1.5 rear for mixed track/street wear was very even for me..6track days different tracks and 11000 street miles .
2017 1LE Hyper Blue
10-31-2018, 09:39 PM | #21 | |
Because Racecar!
As long as toe is kept close to 0, you wont see any difference in tire wear with lots of negative camber. In fact depending on how you drive, that camber might actually extend the life of the tire by saving the outer edge (The spot that wears out from hard cornering) compared to a normal alignment. |
11-01-2018, 01:23 PM | #22 |
"1/LE Rebel Alliance"
Drives: 18 Black 1SS 1LE “Siouxsie Join Date: Nov 2013
So you can get the Chevy recommended Track Alignment and you won't see too much extra wear on your tires?
I only drive the Camaro a couple times a week |
11-01-2018, 08:53 PM | #23 | |
Because Racecar!
Not sure what the Chev track alignment specs are. As long as the toe is kept close to neutral, tire wear should be no different than the "normal" specs. I will attach my alignment settings. How the car sits as a composed daily driver and glorious track day adventure. With almost 20 hours of track time and 13k miles, there is plenty rubber left on the original tires. Been through some aggressive heat cycling so they are not exactly ready to set record laps. |
11-02-2018, 09:17 PM | #24 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
I've found increased camber (more than -1.5) will case the car to drive a bit wonky. Certainly dependent on the road surface (grooves), but there is a reason no car from the factory has that kind of spec.
Got my 1LE updated to -1.5 today - pretty happy with it on the way home. I added .5 negative over the off the showroom floor due to the excess tire wear on the outside edges of the front. Lifetime warranties...my experience unless you know the employees...a Toe and Go is usually their MO. A good alignment is not done in 30 minutes...I paid $150 for mine at a performance shop. |
11-02-2018, 10:09 PM | #25 |
Manufacturers build cars for the majority of the customers. The reason cars don't come with camber set more for performance is because the manufacturer knows most owners will not drive to the alignments potential. They offer the alternate specs for those that do want something more aggressive. It's really a numbers game. You sell 3000 cars of a specific performance variety, they expect less that 20% will be driven to the capability of the vehicle. To reduce the chance of complaints and warranty issues they set the vehicles up for the 80% and then give the 20% an alternate setting.
11-02-2018, 11:23 PM | #26 |
I don't find that to be true at all. We have some of the worst roads here in CA and especially in the Bay Area and I set mine up with -2.2 Front and -1.5 rear with just about zero toe .05 I think, it feels just as stable as the stock alignment. I noticed no increase trampling or wandering over the stock set-up. Maybe re-check your toe settings.
Current:
11-03-2018, 05:42 AM | #27 |
Scargoes: Somewhat agree...but usually they set up the car for understeer and allow enthusiast to rebalance the car a bit with an alignment. Rarely do manufacturers allow so much negative camber. My Subaru was lucky to get -1.5. My older M3's camber is **not** even adjustable!
TRZ06: I'm not sure...worst roads?? I used to live there up the street on I-80...Californian's are sheltered to the rest of the world for roads...same here in FL. :-) My experience is different with camber and tire wear. The toe settings are dead on. Bottomline - performance alignments aren't for everyone. If street driven - it is not needed or desired, IMO. Unless you are getting outside tire wear or 'slide' the car on the street - waste of money. |
11-03-2018, 09:15 AM | #28 |
2017 1LE Hyper Blue
