11-17-2016, 07:54 PM | #15 |
Drives: 2011 2SS Inferno Orange Join Date: Oct 2013
So as I stated earlier I'm in the market for a clutch, it's slipping in 4 & 5th Pretty bad if I am under power. And speaking of power, oh my god ! I've had a couple pretty powerful engines in the past, run nitrous and such and tore up my share of small blocks in my day.
This thing is ridiculous I can't stop smiling, it's like my first BJ.
2011 Camaro SS
Buckets of money under hood! |
11-18-2016, 02:24 PM | #16 |
Too much is never enough!
Do something that's rated for a lot more horsepower than you have now, Don't get a Mantic, I have had bad results with their dual disk, rated at a 1000tq. I was only 747 at the time too. Get something that's rated at way more power than your going to use, or have.
This is a great dual disk. http://w.ivenue.com/hendrixengineeri...ayer-twin.html This is the clutch I am going with next http://w.ivenue.com/hendrixengineeri...er-triple.html
