05-08-2017, 01:58 PM | #15 | |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
05-08-2017, 06:45 PM | #16 | |
Loves Camaros
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert Join Date: Sep 2012
I'm gonna clean up and drive it here in a bit to check for the rattle. Tara
Old and new, sharing space!
05-08-2017, 08:47 PM | #17 | |
Drives: 2017 ZL1 Join Date: Oct 2016
Anyone know why youtube vidoes show as a white box for me on this site?
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
05-08-2017, 09:05 PM | #18 | |
05-08-2017, 10:09 PM | #19 | |
Loves Camaros
Tara
05-09-2017, 08:13 AM | #20 |
Resident Land Surveyor
Drives: 2016 Camaro 1SS - Summit White M6 Join Date: Aug 2016
Yep, I found the other thread on it, all good now
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned |
05-12-2017, 06:42 PM | #21 | |
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4 Join Date: May 2015
thanks for the post man! |
05-13-2017, 12:31 AM | #22 |
Drives: 2017 Hyperblue M6 ZL1 Join Date: Jan 2017
I started noticing this last week. It progressed to the point where I thought something was going to fall apart. Only 2600 miles. Brought it to the dealer today under warranty and mentioned what I had read on the Internet. Sure enough one end link was loose. Apparently they didn't need my help - just referred to the service bulletin. Strange that cars keep coming from the factory with the sway bars not adequately tightened. Anyway, thanks for the heads up. So nice to have my sweet ride back...
05-14-2017, 01:22 AM | #23 | |
Loves Camaros
Does anyone have a copy of the TSP on this issue? Thanks, Tara
05-14-2017, 02:08 AM | #24 |
got under my car and tried to tighten these... first attempt at going up on ramps was a bust... literally.. used boards and my rhino ramps and of course I shoved a ramp and then slipped off, came down and cracked the front splitter thing... water came pouring out of it that I suspect was just from rain or something... didn't look like there was any other damage. so irritating!
then I decided to just see what I could do with the car on the ground to avoid the ramps (which I've used plenty times with success, btw). I put the wheel in full lock left and right to get a better view of the endlinks... all seemed tight. thought maybe having the wheel turned removed slack so I put the wheel straight and everything still seems pretty snug although it's hard to snake my arm and a wrench around the wheel with the car on the ground. ugh. 1600 miles on a car that hasn't been tracked and it's already forcing me to futz with stuff to fix it in my garage... not a fan of that and I've gotten rid of cars for less of a reason before.... I really want to track this thing but if parts are going to start falling off ... I just don't know. |
05-14-2017, 03:07 AM | #25 | |
I think your best bet is to find a proper way to jack the car, remove the wheels, apply some blue loctite and torque ( you may refer to my build thread for good seat of jack stands that work with ZL1addons jack points). If you don't have the tools you can always use your factory warranty at a reputable dealer service in your area. I've been really happy with the car at the track ever since I fixed those little things. Hopefully these will be the end of the problems
05-15-2017, 11:35 AM | #26 | |
Loves Camaros
So far, so good! I hope it lasts this time. Tara
05-18-2017, 04:09 PM | #27 |
Don't be this guy (me) and make the same mistake
I was bleeding the brakes and wanted to apply some blue loctite on the swaybar endlinks since the car was already on the jacks.
I couldn't find the torque specs of the stabilizer/end links so I referred to previous gen Camaro's specs and used 38 lb/ft torque initially. Then, recently one of the forum members (cannot recall who) mentioned that he learned that the torque specs and it should be 65-70 lb/ft and it shouldn't be that low. I thought it sounded a bit on the high side but it shouldn't hurt to torque them a bit more (50lb/ft ) since it's a 18mm bolt and nut right? RIGHT? Wrong Long story short don't make the same mistake and over torque them. In the meantime if anyone can tell me the "real "torque values of these, I'd highly appreciate it. And of course, it happened right before my scheduled event this Saturday . I called the dealership this morning and ordered two of those endlinks, even though the passenger side is fine for now. Hopefully they will be there to pick up tomorrow morning as they said and I can quickly put them on and be on my way for the weekend event at the ORP.
05-19-2017, 07:32 AM | #28 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Sorry that broke on ya... don't know what they should be, but given that it broke when you tried to go to 50; you were probably pretty darn close at 38. Also, it may have broke from being stressed from being loose... Just a thought, when you're at the dealership, ask the service folks to look up the torque spec for that.
