07-20-2019, 04:09 PM | #15 |
Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Agree SSport16!!
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
07-20-2019, 07:21 PM | #16 |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
With just fueling and tune they could find the 40hp.
07-20-2019, 10:09 PM | #17 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
The tuning will probably take a while to unlock with the new electronics system.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
07-22-2019, 11:33 AM | #18 |
Drives: 2016 Camaro 2SS M6 Join Date: Mar 2019
I'm thinking that might be the DI pump, on the LT1 its on the back of the engine driven by a tri-lobe cam. They could have moved it to the front and made it chain driven
07-22-2019, 01:59 PM | #19 |
Drives: 2016 Camaro 1SS Join Date: Mar 2019
Most likely. I thought I saw somewhere the LT2 is using the E99 ECU which is the same one in the ZR1. Which if thats the case tuning is going to be EXPENSIVE on the corvette. Currently it'll run you $2000 for an unlocked ECU and another $500 in tuning credits for hp tuners.
Red Hot 2016 Camaro 1SS 6M w/ NPP Exhaust, Speed Engineering 1 7/8" long tube headers and catless xpipe, lethal garage flex fuel kit, self tuned
07-22-2019, 06:49 PM | #20 |
Drives: 2016 2SS 8AT Join Date: May 2018
Is it just me or do the heads look different?
07-23-2019, 01:04 AM | #21 |
Drives: 2019 Camaro SS Join Date: Jun 2019
I plan on seeing if the intake will fit on the camaro. If it’s 1 inch shorter than the truck intake it will fit. I bought a l86 intake to see if you could make a truck intake for and it was surprisingly close.
2019 Camaro 1SS A10 River Side Blue
Max effort tuning llc Rotofab dry, ported msd, nw 103mm Tb , speed engineering 2” headers, velossa tech,ati ud, aerospace front brakes, and flex fuel |
07-23-2019, 03:18 AM | #22 |
Drives: 6th gen Join Date: Aug 2013
If you could just lower the cradle a tad that would just slide on
07-23-2019, 09:05 AM | #23 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
I think if you use the aftermarket motor mounts you just might have clearance.. I believe they drop the motor about 1 inch... not 100% sure
Florida High Performance: H/C Whipple LME 377 900WHP
07-23-2019, 10:07 AM | #24 | |
We will see whenever the lt2 intake is available to purchase I’ll go ahead and order it and see what all it takes to make it work or not work. Should be a nice upgrade though.
07-25-2019, 10:04 PM | #25 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I just saw a car and driver page that apparently says the only thing different about the cam in the LT2 is the exhaust lobe, intake lobe is apparently the same. The exhaust lobe has more lift. The intake manifold and headers are obviously different and look improved, and the dry sump system is supposedly supposed to reduce frictional loses. So supposedly the LT2 makes 35 more HP from mostly the intake? Main reason I say this is look at the difference in the C7 LT1s and Camaro LT1 headers, the Camaro headers look better but we know the factory ratings for the engines are the same, minus the NPP option, even though I've tested myself the 5hp increase from the Camaro NPP.
08-01-2019, 10:45 AM | #26 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Is it possible that the LT2 intake simply be able to be turned 180-degrees and bolted on?
Is it possible it is that simple? Or is there possibly some component in the valley area that is in the way? The cylinder head port offsets don't line up right? I've not had the intake off my LT1, but I know many V-engines you can rotate the intake 180 and it will bolt on... |
08-04-2019, 07:00 AM | #27 |
Does anyone know if you can loosen the cradle bolts to get a 1/2 inch to sneak that truck intake on. I think once it’s on the engine it will fit without issues
10-22-2019, 07:29 PM | #28 |
Good video on LT2:
https://youtu.be/6gOSpzQzqf0 GM states the LT2 runners at approx 210mm and that the manifold sits 2-3 inches higher than LT1. Given that the L86 intake can fit on the Camaro... Interesting that the engineers confirm my thoughts on the LT1 intake manifold: plenum volume/cross-section is compromised for the C7 hoodline and the intake manifold is a restriction to the LT1, even from an OEM standpoint. -LT1 runner lengths are approx 185-225mm (2 and 7 are shorter). *Plenum vol.: 11.1L -LT2 runner lengths are approx 210mm *Plenum vol.: 14.1L -Holly Hi-Ram lengths are approx 165mm *Plenum vol.: 9.0L -MSD runner lengths are 178mm *Plenum vol.: 11.22L -L86 runner length? Last edited by Mountain; 07-24-2020 at 02:54 PM. Reason: Added MSD runner length & plenum vol. |
