#15 |
Drives: 2010 Camaro Join Date: Feb 2010
You need a Cartek track rental. At those you need to wet your own water box! You'll be fine.
#16 |
Drives: 8 second C5 Drag Car, C6 Road racer Join Date: Sep 2009
#17 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
Whoo Hooo. That's what I'm talking about.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
#18 |
#19 |
That would be great, especially since the rear is getting worked on. I'll have more of a comfort level with driving it a little harder now.
#20 | |
See Jamie, some people are trying to include you. ![]()
#21 | |
Cool, Thanks Doug. I've never seen an ECS rental with public info so I didn't realize you guys had them as well. I'm def in and so my father also. That's only until you get to know me then the invites stop.... ![]() |
#22 |
That's ok, I usually end up inviting myself to places, so this invite is a nice change of pace. I feel wanted now.
#23 |
#24 |
No biggie, the fat ones usually have the best jokes and are funny. At least the ones I knew.
#25 |
Hasbin of Stock Bottom HP
#26 |
#27 |
When do you think you'll ever hit a 9.50? You need to work on breaking the 9.80 margin first just as I need to make a single run down a track.
#28 |
With this storm coming, it's a good thing I'm not in a rush.
