02-16-2014, 06:55 PM | #15 |
Drives: 2013 2SS 1LE Track Ready Join Date: Dec 2013
Same - Mobil full synthetic 5W-30.
One of the Sr. track techs recommended I use Red Line racing oil with more viscocity. I am looking into this. The Mobil One is to light for road course I am told. Ended up sending out the engine block to LME in Texas and had it bored and stroked to a 416ci monster. |
02-16-2014, 07:10 PM | #16 |
Drives: 13' 1LE Join Date: Apr 2012
Cant believe this is still a problem!!! When GM is gonna fix this BS!!?? I thought it was gone from the early 10' ...
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
02-17-2014, 04:48 AM | #17 |
If the pump goes while driving you really have to hope it takes the engine out. Just think driving, pump goes, you pull over as fast as you can but hear noises from engine. WOULD YOU REALLY WANT THEM TO JUST REPLACE THE PUMP?
02-17-2014, 10:45 AM | #18 |
Drives: 2013 2SS/RS/1LE Join Date: Dec 2012
That is my fear for the moment - when my oil pressure dumped was coming off exit ramp, by the time I got it whoa'd down, it was making a lot of noise, think I might want more than a new pump?
02-17-2014, 11:40 AM | #19 |
Drives: ‘13 1LE Join Date: Jul 2013
02-17-2014, 12:51 PM | #20 |
Pennzoil Platinum 5W30
02-17-2014, 09:15 PM | #21 |
Well I'm glad we finally got a Penzoil Platinum user to chime in, phew!
For a few instances there, I was beginning to think that..... |
02-18-2014, 01:52 AM | #22 |
Banned
Drives: 2013 CRT ZL1 Join Date: Sep 2012
I have my blower going in at the end of march, should I get a new oil pump put in at that time? Will this solve ever having to worry about this?
I never want to deal with this. I have 3800 miles on my car. tx... |
02-18-2014, 05:21 AM | #23 |
I would. I haven't read any oil pump failures from anyone who swapped out
2010 Camaro 2SS/RS LS3
1093/1066 416, AGP 6262, E85, Cam |
02-18-2014, 06:21 AM | #24 |
Yes, replace your oil pump if you are doing any engine upgrades!!
02-18-2014, 06:59 AM | #25 |
Many different oils used with pump issues. If you want to worry about oil check the thread awhile back about all the motors going bad with Mobil 1 with cam wear and lifter issues.
02-18-2014, 07:12 AM | #26 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
Scott, what about Amsoil, any issues with this and the stock pump. I change mine every 3000 to 4000 miles on my 2012 SS, 49000 miles and no issues as of yet. I do swear though one time I went 7000 miles and my engine was telling me something like change oil please.
02-18-2014, 08:46 AM | #27 |
Never heard of an Amsoil problem with lifters and cam wear. The oil pump though is a design flaw, could happen with any oil.
02-18-2014, 12:09 PM | #28 |
Update on Oil Pressure Issue
Talked to the dealer tech last evening - new motor on the way in a couple of weeks. When they dropped the pan to change pump, lots of chips - appears the crank buried itself into the thrust washer, all downhill from there.
