09-08-2023, 02:47 AM | #15 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
09-08-2023, 11:06 AM | #16 | ||
Drives: 2011 Chevrolet Camaro SS L99 AT Join Date: Oct 2021
Additional ground was made for the starter and engine but today again i looked to a slow cranking and no start after I have sit on the throttle pedal on highway Do you still insist on replacing the battery?
2011 Chevy Camaro SS AT L99 / Stock / Daily Driver
1972 Plymouth Barracuda RB V8 3X2-barrel Holley R-4382A/R-4375A/R-4383A (Hamtramck) / Stock / Weekend Driver |
09-08-2023, 11:15 AM | #17 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Still getting the DTC P0336?
09-08-2023, 12:00 PM | #18 |
no. just slow cranking, it doesnt pull this DTC every time. I get P0336 (and stabiltrak) if engine starts after several unsuccessful attempts only. In that case I usually I wait for a 5 10 minutes and it starts without any DTC.
09-08-2023, 12:17 PM | #19 |
09-09-2023, 02:40 PM | #20 |
Drives: ABM #93 Join Date: Oct 2018
It’s not so much the hot engine needing more battery power, but when the starter gets hot it becomes less efficient, so in turn it needs more battery power. This is amplified by a weak battery, bad grounds, and/or a worn starter etc.
In your case I would get the battery/charging system checked. Have the battery load tested. My bet is your battery is on the way out.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
09-10-2023, 02:02 AM | #21 | |
my worst guess is the worn crank bearings, I found that when engine is hot and bearings are worn out, engine wlll start hard
