#15 | |
Her Name is Mila
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS Join Date: May 2012
Any time you remove a tire from a wheel, it would have to be checked on the balancer. In some cases you get luck and, your wheel requires no weight because its in perfect balance already. Flipping a tire, if not direction can be done. However, the inside tread pattern and sidewall writing will not match your other three wheels. Usually, the inside sidewall writing is not very cool looking because most manufactures expect it to be on the inside. Theres one exception to the balancing rule. If you remove the tire make a mark with the valve stem (or you could make the tire with the rim) you can replace the tire back onto the wheel in the same spot, thus requiring no balancing as the tire should have been balanced before hand. This is not an easy thing to do and as I see you are not going to do this yourself. And before anyone yells at me for doing that. It is not a usual practice. However, I do it in a crunch such as, when my I am waiting for the Snap-On guy to come recalibrate my balancer and I need to patch a tire. Good-luck OP. Ignore all the ignorant, sarcastic people on here. F**king losers.
#16 |
USMC 1980-1990
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2012
Wow that went sideways quick
USMC 1980-1990
My other toys are Harleys |
#17 |
ITS ALL IN GOOD FUN AND FUNNY UNTIL SOMEONE CALLS HIM OUT AND SOBERS UP THE MOOD. I THOUGHT IT WAS FUNNY TOO!
2014 Chevy Camaro 2SS/1LE
K&N CAI, Magnaflow cat-back exhaust. |
#18 |
![]() Drives: 2015 2LT/RS Vert Join Date: Mar 2015
I don't think anyone has mentioned that many of these tires have assymmetrical tread. My tires are marked "This Side Out".
Mel
2015 2LT/RS 'Vert, RRM/Blk Designated Airworthiness Inspector; specializing in Amateur-Built and Light-Sport Aircraft. USAF Vet. <n168tx(at)flytx.net> |
#19 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
might want to re-use the air save a few cents
#20 |
Not all the tires available for these vehicles are gonna be asymmetrical, so it is a valid question.
Yes, he should definitely recapture the air. We are running out of it. It is a premium now.
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
#22 | |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
![]() Some of ya'll are as touchy as the Ecoboom vrs V8 folks. Now, play nice in the sandbox or
#23 |
#24 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
#25 |
376 cubic inches of fun
Well of course you have to rebalance, plus make sure your tire is neither directional not asymmetrical.
Directional: tire must rotate in the indicated direction. Asymmetrical: tire has an inside and an outside. Some tires are asymmetrical but NOT directional. Example: P-Zero summer tire on SS can be switched from side to side without remounting. Some tires are directional but symmetrical (no inside or outside) like the BF Goodrich Comp-2 tires I just put on my SS. Thee is no difference between right side and left side tires, but tire must be remounted when switching sides. Some tires are directional AND asymmetrical. |
#26 |
![]() Drives: 2010 2LT, switchblade silver Join Date: Mar 2016
10,000 comedians out of work and these trolls think they are funny.
#27 |
#28 |
![]() Drives: 2011 2SS/RS 500+ h.p. monster Join Date: Feb 2016
Lmao.....good stuff!
