08-16-2016, 02:41 PM | #15 |
Drives: 2013 SS Camaro Join Date: May 2015
Order placed. Estimated availability is 08/20/16... we'll see how long till I receive them. In the meanwhile, I've rotated my set of 285/35R-19 from front to back and left to right for an event this weekend at El Toro.
08-16-2016, 11:51 PM | #16 |
You shouldn't have any issues with that fitment. As Nilfinite said I run an 18x12 with 0 fitment or rubbing issues.
Before now I ran 305x20" Hankook R-S3's on ZL1 replicas. That combo did rub the fenders a little. I pulled them by hand and added max negative camber and the rub disappeared. I would bet the 305 RE71 is shorter than the 28.5" tall Hankooks which pretty much removes any worries I would have about rubbing |
08-17-2016, 06:13 PM | #17 |
Drives: 2013 1le 2ss rs black Join Date: Jun 2016
FZSS, I have the same fs01 1le offset and measured the Clearence between the strut and tire bulg ( widest part or the tire) 1/2 inch all day long. Neg 2.3 camber FS
I'm going to do the same next year, 71's are the shit! Put on my 32mm bar today from you know who? Lol |
08-17-2016, 10:13 PM | #18 | |
08-18-2016, 07:42 PM | #19 |
Drives: 2013 2SS (sold) Join Date: Jan 2016
I think you need camber bolts or camber plates to get that much camber (I have plates and am at -2.3, 7 caster)
Track Parts/Stock Parts Part Out http://www.camaro5.com/forums/showthread.php?t=515534
08-18-2016, 08:35 PM | #20 |
Tires are in! Cannot wait to get them mounted! Will post a comparison of these against the 285/35R-19s after the next event!
08-18-2016, 08:37 PM | #21 |
08-18-2016, 11:42 PM | #22 | |
Drives: Camaro 1LE Join Date: Nov 2015
Looking forward to hearing your thoughts! The extra rubber and shorter gearing should be a good improvement over the 285s. |
08-19-2016, 10:41 AM | #23 |
I unfortunately don't have a 1LE. :-/ It's a stock 2013 1SS suspension with BMR front/rear sway, BMR 1.25" springs, and 3.91 gears.
08-19-2016, 01:16 PM | #24 | |
If I could also make a suggestion. Since you have the 3.91 gears. What about turning your car into a 1LE and running in FS? You need just one 1LE sway bar, the stock SS springs (same as 1LE) and 1LE-based wheels. Sounds like you already have the right wheels. Much cheaper to max out a FS setup for AX than a CAM setup! Here is some info on F-Street rules. http://www.camaro5.com/forums/showthread.php?t=431921 |
08-19-2016, 01:23 PM | #25 | |
I should have also mentioned that my car is pushing close to 500 rwhp with cam/headers/intake/etc. |
08-19-2016, 04:02 PM | #26 | |
08-20-2016, 11:37 AM | #27 |
Drives: 2013 BMW M3 Join Date: Jul 2016
08-20-2016, 02:02 PM | #28 |
