02-15-2018, 07:05 PM | #15 |
Drives: 2014 Camaro SS L99 Join Date: Nov 2017
Yes sir, Thanks for the help guys. Everything is torqued down and valve covers are on. Assuming everything continues to go smooth I should be able to start it up tomorrow night. " It will either be a great launch or the best fireworks display" lol, either way you guys will all hear about it.
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
02-15-2018, 07:15 PM | #16 | |
Drives: 2012 M6 Camaro SS (RIP) Join Date: Nov 2014
Really? I had no idea Where did you find this out? Also do you do this before every start?
Speed engineering 1 7/8 LTs, CAI inc Cold Air Intake, offroad connectors, Solo performance axle back with J pipes, tune, and in need of a driver mod LOL
02-15-2018, 07:15 PM | #17 |
Drives: 2010 1SS Join Date: Aug 2015
Looking forward to hearing her!
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
02-15-2018, 08:21 PM | #18 | |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
and no, not before every start...this would be used when the lifters need a pre-lube before first fire..
02-15-2018, 09:27 PM | #19 | ||
Drives: Miss Con Ception Join Date: Aug 2016
2011 1SS/RS LS3 CGM
02-15-2018, 09:59 PM | #20 |
lulz... bought used...owners manual?
02-16-2018, 12:22 AM | #21 |
Drives: 2011 2SS/RS Camaro Join Date: Sep 2017
Owner's manual? We don't need no stinkin' Owner's manual.....lol
02-16-2018, 08:42 PM | #22 |
2011 1SS/RS LS3 CGM
02-16-2018, 10:14 PM | #23 | |
awesome..you have an owners manual and you can read...point established...have a great weekend!
02-17-2018, 12:08 AM | #24 | |
What did the hand say to the face?...........SLAP! That's what my mama would say to me whenever I smarted off~LOL! Last edited by el Wulf; 02-17-2018 at 12:20 AM. |
02-17-2018, 02:12 PM | #25 |
Whelp....... First start up=No Bueno
https://youtu.be/KWzqy0pT4Pg I Still have to wait a few days for my remote tune, I'm actually in the cab holding at 1k... when it surges its because I let off. But regardless i'm pretty sure that squeak/chirping dosent have anything to do with a tune. It sounds like lifter failure vids I've seen..I only ran it for two mins tops. what do yall think
02-17-2018, 02:40 PM | #26 |
if you had a lifter failure you would know it...I wonder if that squeak is the same go go had on his first start...his thinkin was water pump...what is the level of the coolant?
02-17-2018, 02:44 PM | #27 |
Very low, Only filled with 2 gallons, Need another one plus some apparently.. Car hasn't even ran long enough for it to work through yet. Don't wanna run for extended periods until I get my tune files.
02-17-2018, 02:46 PM | #28 |
Also forgot to mention but i dumped a quart over the valve train, cam has assembly lube, and lifters were soaked in oil for several days before install.
