02-20-2018, 08:32 AM | #15 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Shameless self promotion Bo! LULZ...do I qualify for a discount helpin with marketing?
02-20-2018, 09:24 AM | #16 |
Maybe. Maybe not lol.
02-20-2018, 10:43 AM | #17 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Wonder if anyone has successfully R&R'd the pump without lowering the pan? I've seen claims of it on LS1tech but no details.
Removing the pump guts under the hex bolts. I guess it would depend on if a wrench could be snaked in on that bolt. Maybe someone has Macgyvered an interestingly shaped wrench. If one could get the pump off/on without dropping the pan, that would simplify changing to a dogbone/C5R chain along with a cam job. |
02-20-2018, 10:51 AM | #18 | |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
That ~3/4" drop from lowering the pan seems to make ALL the difference in the world. Not saying this is impossible (with some kind of custom tool)...but I don't see how one could reasonably get it out with the pan bolted in place.
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
02-20-2018, 10:53 AM | #19 |
Drives: 2010 1SS Join Date: Aug 2015
Tough call.. I took a real good look at mine before I dropped the pan.. If there is even a way I think it would be more work than dropping the pan.. that is the quick part. Getting the pump off and back on the crank in position is the real challenge with the PU tube in place. I know some have removed the pump guts for more angle room but I didn't have to. With a little patience I was able to get things lined up just enough to get it back on. I also put the bracket in for added precaution.
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
02-20-2018, 05:50 PM | #20 | |
Next time I have a front cover off I may give it another shot. |
02-20-2018, 06:02 PM | #21 | |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
this guy does it with a hack he came up with. didnt drop the pan
Bone Stock |
