#15 |
1AS2RSK
Drives: 2013 ZL1, # 1668 Victory Red Join Date: Jan 2012
My dealer pulled it for me on the PDI. No code set. Sounds great
#16 |
BAD ZL1
Drives: 2013 VIN 48 Victory Red ZL1! Join Date: Jan 2012
Something close to this. With fuse in, Flaps are open from 0-1100 RPM then close at 1101 to 3100 RPM, then open from 3101 to 6200 RPM. Im sure the RPM's I have given are not exact.
Remove the fuse, and flaps are open 0-6200 RPM 100% of the time, which is what I did. I love the sound, I dont think it has a droan, and you can still have a conversation in the car unless you are WOT, in which case, I dont need to be talking anyway... |
#17 | |
BAD ZL1
#18 |
![]() Drives: 13 ZL1, 10 Silverado LTZ, Chopper Join Date: Oct 2011
See, this is what I originally thought because the flaps would stay open on the exhaust if the fuse is pulled hence making more sound.
#19 | |
#20 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
If you pull the fuse it will eliminate it quieting down at cruise, giving you the deeper sound all the time. |
#21 |
Bayou City Muscle Cars
Drives: 2013 2SS Dusk Edition Join Date: Jan 2013
yup it stays at "Rock n Roll" all the time
![]() good looking and sounding exhaust.
Lethal Racing Stage V PER 418ci Forged LS3 530/520 SAE |
#22 |
Camaro Addict
Drives: too many Join Date: Sep 2009
My car is getting a coolant leak fixed so I walked back and pulled the fuse out myself.
1990 IROC-Z Vert LS
1996 SS Vert LT4 1992 Z28 Z03 T5 1992 Z28 Z03 L98 2018 Sierra Denali 6.2 1997 Z28 Z4C 1995 Z28 |
#23 |
Camaro Addict
its a little better with the fuse pulled, but it still needs some work in the sound department. I'm going to install my exhaust from my SS and see how much of a difference there is with no mufflers but stock resonators, compared to the stock mufflers and no resonators on the Z
1990 IROC-Z Vert LS
#24 | |
![]() Sent from my SPH-L900 using Tapatalk 2
#25 |
Camaro Addict
I was going to do as much as I can without messing with a warranty issue. Headers are in the works, as soon as I sell the kooks off of my 2010 SS. was told they wont work on the Z. older version of the headers. just trying to make it sound better in the meantime.
those cats really quiet down the car a ton.
1990 IROC-Z Vert LS
#26 |
![]() Drives: 2013 zl1 Join Date: Dec 2012
exhaust commander
#27 |
