Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 02-19-2016, 06:40 AM   #15
WVracer
WVracer's Avatar
Drives: '11 2SS/RS LS3 M6 (Sold)
Originally Posted by 2010SSRSM6 View Post
Camp Pendleton is starting to move away from them now. That means the rest will likely follow suit shortly.
You do not have to register in CA and only have to get a smog check to appease the states money grab. 99% of the smog stations will not do anything and send the info to the state so you get your $10 certificate or whatever they are extorting from us now just to make your base happy.
Most of the shops are pond the bases know the requirement. If it sounds like you're getting shafted, you are and find another shop.
Where are you stationed and what part of WV are you from?
I'm stationed at Pendleton, I am from the eastern panhandle of WV, Hardy County
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs.
WVracer is offline   Reply With Quote
Old 02-19-2016, 08:24 AM   #16
2010SSRSM6
2010SSRSM6's Avatar
I've got family in and around the Weston area.
Old 02-19-2016, 10:39 AM   #17
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
Originally Posted by Firebreed View Post
90 to 100% of the bases now (at least the navy bases) dont issue the base stickers anymore. I've never heard of the requirement to register in the state your in inorder to get the base stickers (when they were issueing them) as long as you have your registration and insurance in line you should be good to go.
Sticker requirement is gone for the Navy. I've been able to get on Pendleton, Miramar, and MCRD without stickers every time so I am guessing if they see Navy on the ID they don't require the sticker.
Now, on Navy bases, the car is still required to be registered with the installation for access. Are they checking it at the gate? Not often but they do random and administrative inspections throughout the base so if you get caught up in one of these and your car is not registered then you are looking at a ticket at the bare minimum and likely worse with the chain of command.
You probably will be able to fine shops that will pass you on smog for a "fee". You will have to hunt around for what is going to work for you. Hope that clears it up a bit.
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
