04-24-2015, 12:39 PM | #15 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
I've always used Vaseline, thin lite coat and your good and will not cause you any issues.
04-24-2015, 01:07 PM | #16 |
Look up this ... American Grease Stick Sil-Glyde O-Ring Lubricant used to seal O rings in brake reservoirs.
04-24-2015, 03:58 PM | #17 |
Drives: 2011 2ss blk/wht strp Join Date: Oct 2014
I used high temp grease. a small ammount goes a long way. This sheet
04-24-2015, 06:19 PM | #18 | |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
This.
ordinarily I'd say "never lube an o-ring with anything before you know what the o-ring is made of" but molykote is a good product and we use it regularly on o-rings Quote:
Well, now you know which ones don't know much about their products
04-24-2015, 10:23 PM | #19 |
Drives: 12 Boss 302 Join Date: Sep 2009
I normally use whatever the O ring is going to seal. Vaseline works, and brake slide lube also works. With fuel injectors, just having the seal wet with gasoline will allow it to slip into the fuel rail.
The biggest mistakes in life come when you know exactly what you are doing.
04-24-2015, 10:36 PM | #20 |
The Mechanic
Drives: a sports car Join Date: Dec 2011
