10-25-2022, 03:25 PM | #29 | |
Drives: 2010 camaro ss Join Date: Aug 2021
Very nice!!! Add that to my list of winter projects when I install the Hendrix offset bushings and a 1 piece driveshaft. Sent from my iPhone using Tapatalk |
12-27-2022, 04:07 PM | #30 |
Drives: 2011 Camaro 2SS/RS Join Date: Jan 2011
Drive Shaft Shop came through on replacing my bad aluminum one with their new improved one. Not sure what was improved with the new 2.0 version, but I’m not complaining.
Since I have a Carbon Fiber driveshaft already installed, I’m selling this new aluminum one. Anyone interested? $850 Still in original shipped packaging. Only opened to take pictures. I’m located in SoCal (Azusa to be exact)
Allen
2011 Camaro 2SS/RS |
01-20-2023, 07:08 PM | #31 | |
01-24-2023, 06:58 PM | #32 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Looks like KDS4 T8 is the material 350 stands for 3.5" and 125 is .125 wall thickness. Same tube used by Gulf Coast and Sonnax.
2010 SS - Kind of an On3 kit, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
01-25-2023, 01:47 AM | #33 |
Update: the aluminum driveshaft has SOLD!
Allen
01-25-2023, 02:39 PM | #34 |
Did you have the DEI heat shield on with the aluminum DS before you switched to the CF shaft?
UPDATE- per pm I got from dma05 “ Not at first, but once I found it was hitting the existing sheet metal heat shields, I removed them and then added the DEI. The DEI stuff has been on for both the aluminum and carbon fiber driveshafts.” __________________ Allen 2011 Camaro 2SS/RS Last edited by camguynj; 08-01-2023 at 09:10 PM. |
08-06-2023, 03:04 PM | #35 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Well installed the shaft, Vibration at 80 and above, rotated both adapters two bolts holes ( can't do exact 180 unless you remove the u joints ) Vibration better at 80 but still there and bad at 100 MPH. I am kot happy about this. Gulf Coast aluminum.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
