#29 | |
![]() Drives: 1998 Trans Am WS6 Join Date: Mar 2019
kickass dyno numbers. Did you make those numbers at 17psi? |
#30 |
![]() Drives: 2013 camaro zl1 aka the Reaper Join Date: Apr 2018
bump
definitely want to know about the new 2650 maggie |
#31 |
#32 |
![]() Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
Just spoke with Magnuson, they are available and in stock right now for the LS3/LSA/LS7, name is GM LS3/LSA TVS2650 Hot Rod Kit, but you will have to run a cowl hood or cut your hood because the total blower height is roughly 12" due to having to clear a roughly 5" thick intercooler brick built on the same design as the Heartbeat as compared to the 2" oil cooler style used in the TVS2300, it's setup for 109mm to 114mm throttle body. They are still working on a low profile version for the LT4.
#33 | |
And damn, they really screwed it up by making it so tall. Nobody with an FBody can use it.....maybe not any Vettes either. Not sure how close the Vette cowl is to the back of the SC'er case. Its almost 2 inches taller than the Harrop 2650. Too bad, they just blew thousands of possible sales. |
#34 | |
![]() Drives: 1999 Camaro SS Join Date: Apr 2016
#35 | |
Like mine....its an LQ9 iron (LS) block. I have Brodix LS3 style heads. So it will bolt right on. Its just too bad its so damn tall it will never fit in my Fbody. The Harrop will fit. |
#36 |
![]() ![]() Drives: 14 SS/ 1LE Join Date: Jun 2013
That would be sweet if they made the Heartbeat style unit with the 2650 rotor pack for cathedral heads. The jackshaft unit is just too tall to fit in most cars
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers |
#37 | |
![]() Drives: 2010 2SS RS M6 npp e-force Join Date: Oct 2014
#38 |
Sales rep said Chevrolet Corvette and Camaro LT1/LT4 2650 low profile to fit under the hood was next and they weren't sure if they were going to do a low profile heartbeat style to fit under the hood for the rest of us.
#39 |
![]() ![]() I think with it being 12" tall, it's roughly 3" to 4" taller than the old jackshaft unit, it sets up pretty high therefore needing a COPO Cowl hood or cutout they said. |
#40 |
![]() Drives: 1968 camaro Join Date: Aug 2013
Talk to magnuson last week.told me the 2650 heartbeat version for the LS motor will come out next month ..
#41 |
Sweet. Going to be exciting to see what it puts down
2014 1SS/1LE
#42 |
