#29 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
I use Amzoil and change it every 1000 miles and the start of every season after she hibernates all winter in a heated garage. Sometimes it gets done less than 1000 miles if I don’t drive it much and I just do it for piece of mind. To me it’s cheap insurance.
#30 |
![]() Drives: 2014 Camaro 1LT Join Date: Aug 2019
I've seen this question get kicked around in many a forum, and just about every reputable mechanic I know says to change your oil at least once per year (at MOST once every 18 months). I'm told it's due to water and other contaminants getting into the oil over the course of the year (changing seasons and what not) rather than the oil breaking down due to mileage.
I'm no expert; just parroting what I've been told multiple times. On a side note, I did get banned in a Honda/Toyota forum by the supermoderator on this topic. He took offense to my stating that many a mechanic advises changes the oil at least once per year, rebutting that unnecessary oil changes are bad for the environment and place unnecessary expenses on maintenance. He called me some unflowery names, which I unfortunately returned in kind, and voila...permaban. |
#31 | |
![]() Drives: 2015 Camaro SS/RS 1LE Join Date: Jun 2016
What is the reasoning behind changing it before winter versus after sitting all winter,(in a heated garage) then changing it right before "driving season" ? Just curious, Thanks. |
#32 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
Its good to change the oil at least yearly if you do not put a lot of mileage on it. This is what I do.
The existing oil probably is not doing damage to the engine; However I would not do long distance driving or put hard tasks to the car without changing the oil.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
#33 | |
![]() Drives: 2014 2SS/RS/1LE Join Date: Mar 2015
If GM put an algorithm in the car to tell you to change the oil even if it hasn't reached the designated mileage, then they forgot to put it in mine. I have gone over three years without changing the oil and never got a notification and I'm almost at 2 year now since the last oil change with no notification. My car hardly ever gets driven but I do start the car about every two weeks and it's driven about once or twice every two months. I've never had any issues with the oil sitting in the car for longer than a year. That's just my experience though.
#34 | |
The Maintenance Schedule actually specifies it. I'm also not aware of any vehicle monitoring system alerting the owner of an oil change based on time rather than miles. |
#35 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
One thing you can do is leave it halfway on dipstick e.g. half quart low and boost it with half a quart like 6mo into your oil change. We hope to boil out the water but oil might not get hot enough and a combustion by-product is H20 and it bypasses rings into the oil along with some small amount of condensation depending on the environment and heat cycles. When you said my mechanic said, I cringed, thinking here we go with another 3,000 miles opinion as if we are in the 1970s still. This topic brought out so many people insistant on 3,000 mi changes a few years ago. Maybe a few watched e.g. the mobil 1 video and teardown of a 500,000 mi engine that had long oil changes and no wear or sludge? Nah some people never learn. They probably feel outnumbered and just aren't saying anything now. |
#36 | |
![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
Twofer! ![]() Edit: Threefer since it's kills pear cactus too and not much will.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
#37 | |
My Chilton Repair Manual lists 3k miles or 3 months as the scheduled oil change, but I've never had any reputable mechanic ever list an oil change at that low a mileage/date range. Most of them put me at the 5k-7k range unless I do a lot of highway driving, in which case they bump it higher. |
#38 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Mine comes on at 9% at approx 49 weeks since last change. Only put 300 miles on it since then. Pretty much the same every year. Most of my 9800 total miles were in the the first 2 years. Might be something with 6th gen though. Don't recall my 5th gens doing that. 2016 Silverado doesn't either and only a few hundred are put on it every year. So might be something they recently started doing.
#39 |
i have a 2015 camaro 1 SS and i have a cam and plan to super charge it later this year. It is not my daily driver, i drive it on the weekends if i can. i like to drive it hard and plan to run it on track. i don't put 2k on it in a year. i have a heated garage and put her on a trickle charger during the winter. I still change my oil once a year, it cost me under $60 bucks. For me its a peace of mind and i know the oil is good but i do drive my car rough like it should be IMO. And it justifies my quickjack lift that i have. lol
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill. |
#40 | |
![]() ![]() Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
Oil Life Monitor Calculation Pathways: Engine revolutions – Oil life starts with a fixed number of revolutions and will decrease with each revolution. Cold / hot coolant temperature readings have multipliers that reduce engine revolutions pathway quicker depending on how far from the normal oil temperature the vehicle is operating. Note: If the engine coolant temperature gets above 260°F (126°C), engine overheat condition, the oil life will go to 0%. Mileage from last reset – Starting with MY 2013, the OLM is capped at 7,500 miles (12,070 km) for all GM powertrains except the Volt. In perfect conditions, a vehicle would reach 7500 miles (12,070 km) from the last reset and the oil life left would be 0%. Note: For the 2016-2018 MY Camaro, 2014-2018 MY CTS and 2015-2018 MY ATS equipped with the 2.0L LTG sold in Europe, the OLM is capped at 30,000 km / 1 year. Time – This pathway is a liner function, a fixed decrease in oil life for a given time after the oil life is reset. The oil life will drop to 0% after 1 year regardless of the amount of engine revolutions or how many miles since the reset. |
#41 |
![]() Drives: 2014 Camaro RRM 2SS RS, M6 LS3 Vert Join Date: Aug 2015
There are a lot of things in life that may not be "necessary," but we do them anyway, because we are all different and do our own individual risk-benefit-cost analysis.
I daily drive the car in good weather, about 10K miles a year, and store her all winter. I change the oil (Mobil 1) at about 50% oil life during the driving season, and not too long before and after I store it. I also try not to run the engine above 2000 RPMs until the oil temp reaches 180-degrees. Are any of these things necessary? Probably not. I may be crazy, but it's not that much money to spend on my favorite ride ever, and one I intend to pass down someday. :-)
Dream it - drive it!
#42 | |
Apparently so. I'm not doubting what you are saying, I'm just stating that mine has never done that.
