Old 03-30-2018, 09:03 AM   #29
copoz28
copoz28's Avatar
Drives: 2010 2SS-RS, IOM, M6
I did the Revshift insert and another mode in effort to reduce movement and tighten up the shift feel which it did very well…however that harmonic vibration between 30-40mph and one slightly at higher speeds became to annoying and removed it…so I dropped the dime and installed the MGW shifter and have not looked back...I may look at that 1LE/Z28 factory trans mount down the road if needed.
2SS/RS, Inferno Orange, 6sp, Eibach lowering springs, Eibach adjustable sway bar, Exhaust 2.5" dumps before axle, New ERA OTR intake, TSP LS3 225/230 .617/.612 on a 112LSA cam,
Rocker arm trunion kit, ported/polished heads, JRE Tune, ARH Headers, G-Force Axles, 3.91 Gears, Eaton Detroit Truetrac /w Billet Caps, MGW Shifter,
DynoTech Driveshaft, E2X Catch Can .
copoz28 is offline   Reply With Quote
Old 03-30-2018, 09:15 AM   #30
LETHAL2SS
LETHAL2SS's Avatar
Drives: 2011 Camaro 2SS
I had the MGW in my last camaro and I loved it, easily the best shifter I've ever used, as soon as I can free up the funds, I'll be ordering it, I ordered the 1LE/Z28 yesterday evening... that plus a full poly bushing upgrade should get this car feeling alot more solid...
It's strange how loose and soft the car feels with only 20k miles on it, my 40k mile 2010 felt a lot more solid even before I built either of them...
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp
LETHAL2SS is offline   Reply With Quote
Old 04-21-2020, 08:04 AM   #31
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Originally Posted by LETHAL2SS View Post
Yup, I'll get this trans mount installed and hopefully all my ailments are cured LOL
If not, its only money!
Did you ever install the Z/28-1LE trans mount? If so, what'd you think of it?
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 04-21-2020, 08:06 AM   #32
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
Poly redshift in mine with solid bmr mounts car vibrates for sure but settles down with more miles. Feels solid and precise would recommend for a max street car
_Onyx_Wolf_ is offline   Reply With Quote
Old 04-21-2020, 08:14 AM   #33
acammer
acammer's Avatar
Good info. I need to climb under mine and confirm, but I'm pretty sure my stock 2011 trans mount is pretty beat up. Got the cradle tightened up on aluminum bushings, the diff on BMR Pro's, and so now the trans mount has been the only thing left other than motor mounts with some give to it. I may just try the 20952439 mount with a rev-shift insert and see if I can tolerate the NVH.
Old 04-21-2020, 01:24 PM   #34
_Onyx_Wolf_
It’s gonna be loud at first but give it like 500 miles lol after that it’s pretty nice with the shifts a little smoother and turning corners feels planted. When u install the rev shift make sure u jack the trans up enough or it won’t fit lol I learned the hard way.
Old 04-21-2020, 09:47 PM   #35
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
I have a revshift insert sitting in a box. I forgot all about it until I saw this post. Lol
More to come.
Black_SS10 is offline   Reply With Quote
Old 05-13-2021, 07:19 PM   #36
Ron_2010_SS
Drives: Chevrolet Camaro SS
Hey guys, I once ordered the rev shift insert and upon installing it with my stock trans mount I put the car back down and 2nd gear was hard to get into. I then took the modified mount off and ordered an original trans mount and has no issues after that what could have caused this ?
Ron_2010_SS is offline   Reply With Quote
Old 05-13-2021, 07:36 PM   #37
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I took the revshift back out of mine, NVH was just too obnoxious...even for me.
