03-09-2015, 06:46 PM | #29 |
Always Workin
Drives: 2021 Mazda MX-5 Join Date: Aug 2013
Is the feeling in your leg when your driving the car? lol
2023 Vivid Orange 1SS 1LE 6MT
Arrived 8/31 Purchased 9/3 2018 1SS 1LE, HyperBlue Metallic (Sold) 2014 1SS 1LE, Black, Twin Turbo (Sold) |
03-09-2015, 09:55 PM | #30 |
The awesome of awesome original stock clutch with 60k miles on it.
03-10-2015, 04:36 AM | #31 |
CamaroFans.com
Not yet... but it's coming on.
03-10-2015, 11:43 AM | #32 |
Drives: Silver 2SS, 68 Firebird 400,70 vett Join Date: Jul 2009
Centerforce Dyad. I'm at 700rwhp and it showed no slippage on the dyno, I have the single disc dual friction, my buddy has the twin disc version with 900rwhp with lots of drag racing on slicks and works really well, and both drive just like the factory with no noise what so ever. Will note I'm on drag radials and no drag strip launches.
03-10-2015, 04:18 PM | #33 |
Too much is never enough!
Mantic 9000 here. Stock pedal, a hint of chatter.
03-10-2015, 04:44 PM | #34 | |
Drives: Chevy Camaro Join Date: Dec 2014
Obviously we're super biased but for your needs the DYAD would be perfect. The DYAD will hold up to 1300 lb-ft and each one comes with a sheet telling you the specific clamp load and holding capacity for your specific clutch. The pedal effort is very close to stock, and in some cases lighter than stock. Also, the DYAD is one of the quietest multi-disc clutches you can buy once its broken in. Sure, there are cheaper clutches out there, but once you go DYAD you'll never need anything else.
Just a little video we did at SEMA a couple years ago that goes into some of the advantages of the DYAD.
03-11-2015, 10:18 AM | #35 | ||
Drives: 2017 zl1. Headers intake pulley e Join Date: Oct 2014
03-11-2015, 10:24 AM | #36 |
Without getting into it, you couldn't pay me to run a centerforce. Seen way too many issues, even with new duals.
Nick
Corvette Z06 -1200ish rwhp |
03-11-2015, 10:25 AM | #37 | |
Drives: Autobot Join Date: Jan 2015
2400 to 800?
03-11-2015, 10:51 AM | #38 |
Always Workin
If it helps I've been running back and forth between Monster and the Mantic. If you add a slave to the monster they're the same price lol (mantic comes with one in their kit and monster is optional).
03-11-2015, 10:51 AM | #39 |
Drives: 2014 SS Join Date: Jan 2011
You don't need to spend a ton of money guys, buy a Monster and install it, if you don't like it I'll refund you and will pay to put another brand in... I'm that confident.
I've got a S in my car that makes a touch over 500 rwhp, it's fantastic! We've got guys running 8's with our R's, tons of people over 1000 rwhp with our setups and no issues. YOU DO NOT HAVE TO SPEND A TON OF MONEY TO GET IT DONE RIGHT. |
03-11-2015, 10:53 AM | #40 |
Also, keep in mind our setups have a one year warranty, none of the others mentioned in this thread have that.
03-11-2015, 10:56 AM | #41 |
Always Workin
Steve. You're to aggressive! Hehe. Pm me your number (I'ml on phone can't see signatures). Make me a deal I can't refuse.
I want; LT1-SC Basic kit Steel flywheel Billet support Speed bleeder
03-11-2015, 11:00 AM | #42 | |
What's your zip code? |
