02-21-2019, 04:30 AM | #29 | |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
Did you flash the TCM to your SS tune and did it work fine? It is a CTSV 6L90. I know the CTSV is a lot heavier than a Camaro SS. My friends 4 door was 4400 on the scale at Beech Bend Raceway. My SS was 4040 with me in it and 3/4 tank of 93. It’ll be heavier now with the ProCharger D1X and all now. I bet 100 lbs easy. Sent from my iPhone using Tapatalk
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite Last edited by John_C; 02-21-2019 at 05:45 AM. |
02-21-2019, 05:41 AM | #30 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
Yes, on my car anyways. the TCM needed to be reflashed to a ZL1 file matching the year of the transmission. Then you can tune it as before.
Mine was 3880 with 1/4 tank of fuel last time when we had the alum block and the 17" wheels.ZL1 diff. I haven't checked it again with the LSX block yet.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
02-21-2019, 05:44 AM | #31 | |
LSx FTW!!!
Can you confirm that works?
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
02-21-2019, 11:02 AM | #32 |
Same TCM yes, but the file itself is different(my case it was anyways) I just brought(towed) my car to the dealer and told them to reflash the TCM to a ZL1 file from the same year as the transmission,Mine is a 2013 model,so I used a 2013 ZL1 Vin number,the tech needs to put a vin number to reflash.Think 2012-2015 would also work if they use the same TCM module.Once the tech reflashed it,I drove it home.
02-22-2019, 03:27 PM | #33 |
LSx FTW!!!
The DSS driveshaft came today...
02-28-2019, 06:34 AM | #34 |
LSx FTW!!!
Changed it up... went with the fan cooled trans fluid cooler.
This one is the same, just without fans. Oil thermostat-180F Fan wiring harness Some of the fittings and Bowler -6AN manifold Got two 20ft boxes -6AN line Rear main seal and rear main seal cover gaskets Case of fluid ZL1 trans support and mount plus driveshaft safety loop Sent from my iPhone using Tapatalk
03-03-2019, 10:10 PM | #35 |
Drives: 2015 2SS/RS with Twin Turbskies Join Date: Dec 2017
Sent you a PM Hammdo
04-09-2019, 09:51 PM | #36 |
LSx FTW!!!
And so it begins...
04-09-2019, 10:17 PM | #37 |
'It's an experiment'
Progress!
-Don
747 RWHP 794 RWTQ
04-09-2019, 11:07 PM | #38 |
LSx FTW!!!
I definitely measured right because that Holley oil cooler fits in there like a glove on top of the Stage 2 ProCharger intercooler!
The fans are tucked in nicely on the backside of the cooler. This was probably one of the most expensive trans cooler setups I could have chosen, but I think it'll payoff in the end. It won't over cool in the winter cold months with the thermostat and it'll definitely keep it cool in the heat.
04-15-2019, 07:03 AM | #39 |
LSx FTW!!!
Ran in to a snag...
Was under the impression that the ZL1 and CTSV cross members bolt hole locations were the same, but they’re not! The CTSV tail has the mount holes farther back, so now we have to fab up a mount to make it work. Not even sure if we’ll be able to make the driveshaft loop work now. Sent from my iPhone using Tapatalk
04-18-2019, 11:08 PM | #40 | |
LSx FTW!!!
Snag resolved by my shop guy...
04-18-2019, 11:28 PM | #41 |
Nice solution!
-Don
747 RWHP 794 RWTQ
04-19-2019, 12:05 AM | #42 |
LSx FTW!!!
I'm lucky to have some smart dudes around here with the tools to do this stuff.
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite Last edited by John_C; 04-19-2019 at 06:36 AM. |
