04-14-2015, 02:16 PM | #29 |
HTCC Member
Drives: 2018 ZL1 1LE HBM Join Date: Oct 2014
It looks like if you want the heat shields you go with 22829478 but still have to buy them separate. If you do not want them you go with 22829477. Both numbers are for the dual mode exhaust
04-14-2015, 02:24 PM | #30 |
You mean if you don't heat shields then 22839578 and if you do then 22829477. :o
04-14-2015, 02:28 PM | #31 |
HTCC Member
I fixed it above. But the way I see it on that website is if you don't want heat shields 22829477. both numbers are for the ZL1 rear diffuser
04-14-2015, 02:35 PM | #32 |
HTCC Member
If you want heat shields 22829478. you will also need 20957052,20957053 and 11516807
04-14-2015, 02:37 PM | #33 | |
Drives: 2015 Camaro 1LE Join Date: Jul 2010
04-14-2015, 02:42 PM | #34 |
04-14-2015, 03:22 PM | #35 |
04-14-2015, 03:27 PM | #36 |
HTCC Member
All the brackets and T20 torx you need are already on you car
04-14-2015, 04:00 PM | #37 |
Drives: 1LE Join Date: Feb 2013
LOL, you guys are killing me.
But, I am sincerely appreciative of the time you took to help EDIT: I'm not convinced that 22829477 is a ZL1 diffuser. Why would they list a different part # if you are not connecting the shields? The only way that would make sense is if they made NPP ZL1s both with and without heat shields . . . |
04-14-2015, 04:22 PM | #38 |
HTCC Member
I did some research 22829478 is the ZL1 diffuser. 22829477 is the 1LE diffuser sorry for the mix up
04-14-2015, 04:31 PM | #39 |
And now we have clarity! Thanks so much.
If you want the ZL1 diffuser, order: 22829478. Optionally, you can order the shields, 20957052 and 20957053. Only question would be whether the rivets for the heat shields, 11516807, are anything special or just standard hardware and not worth the time/expense. |
06-22-2015, 04:24 PM | #40 |
War Horse Pilot
What color does this ZL1 diffuser come in? How much was it to paint it if you have done so?
06-22-2015, 08:36 PM | #41 | |
aerosportconcepts@gmail
Drives: '15 1SS-RS/1LE (RRM) Join Date: Dec 2011
Thank you Kurt Robinson Aero Sport Concepts
06-22-2015, 09:17 PM | #42 |
War Horse Pilot
Thanks!
