08-15-2014, 06:34 AM | #29 |
Ok will do
Go Hard or Go Home
08-15-2014, 06:43 AM | #30 | |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I'm going back tomorrow and I'm cutting 2.0x 60s with drag radials and all suspension mods |
08-15-2014, 07:01 AM | #31 |
I am by no means a pro drag racer . But H-E gave me some good advise about suspension alignment and confidence to go make it happen. I don't even want an automatic now.
According to H-E "You drive a stick and ride in an automatic" That's his quote lol
Go Hard or Go Home
08-15-2014, 10:29 AM | #32 |
Jason
Drives: 2011 2SS/RS M6 Join Date: Apr 2011
I'm getting ready to get an alignment in a week or so after installing my 9" kit along with new toe rods. Mind giving up the alignment specs or are they secret?
Kook's headers w/ high flow cats, Borla S-Type, VMAX ported throttle body, CAI Inc. intake, Jannetty race scoop, Roto-Fab washer bottle relocation, Jannetty rough idle blower cam, DSS 9" w/ 3.70 gears, RPM Level 6 trans, Street Slayer Twin Carbon clutch, MGW Shifter, Pfadt trailing arms.
08-15-2014, 03:00 PM | #33 |
Drives: 416 w/TH400 Join Date: Mar 2012
The ZL1 kit you can get for around $3500 sometimes cheaper and sell your 1000hp axles to help offset the cost and you would be around the same as your stock upgrade
ERL 416 - 12.5 cr, TH400, Custom VVT Cam, PRC 255 heads, NW 102 TB, Aeromotive stealth fuel system, Fast 102 plumbed with a nitrous express direct port kit, BMR 15" conversion kit
08-15-2014, 03:30 PM | #34 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
NITROUS ,will do that .
OLD GUY FLYING FAST AND LOW
08-15-2014, 06:54 PM | #35 |
Do the zl1 diff. Its proven to be bulletproof. I talked with the head gm engineer at c5 fest and he said they did not break a zl1 diff during testing. I know quite a few guys on here pushing 1000+ rwhp without even a hickup. I just recently bought one for my conversion. Going to install it with my adm billet subframe bushings upper carbon solid mounts and my rear adm 15 inch wheel brake and suspension kit.
08-15-2014, 07:01 PM | #36 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
08-15-2014, 07:11 PM | #37 |
One question ........ How is the ZL1 posi and do they make a aftermarket posi for it
08-15-2014, 09:43 PM | #38 | |
Very impressive... Must be leaving 5500+
08-15-2014, 10:25 PM | #39 |
Actually it was about 4500
Go Hard or Go Home
08-16-2014, 08:14 AM | #40 |
See your already wanting to mod the zl1 diff lol....The zl1 isn't the way to go with my money imo...Your still stuck with the factory 2pc shaft and even tho the axles are better than the ss they are far from unbreakable. I like to do things once and be done with it, it's cheaper in the long run.
