11-04-2022, 07:53 PM | #29 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
I removed mine when I wrapped them. Very easy to remove and you can wrap the film on the underside and also not have to worry about a blade near your paint.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
11-05-2022, 12:09 AM | #30 |
I’m Magik a physco dog
Drives: '15 1LT/RS & '23 3LT/RS Join Date: May 2016
Mine have some cracks in them from the brutal Cali sun were it lived before i got it so i'm guessing if i try to remove them they will break apart.
Is there a specific Chevy part # for replacements? I don't believe wrapping them will work.
2023 3LT RS Shadow Gray
2015 1LT R/S Blue Velvet Coupe. Previous: 2015 1LT Ashen Grey 2016 1LT Blue Velvet My entire life has been 'A Midlife Crisis' |
11-05-2022, 09:44 AM | #31 | |
Drives: 2SS/RS Join Date: Sep 2008
That is for one so you will have to buy 2 of them. |
11-06-2022, 12:54 PM | #32 |
@ Mr_Draco, thank you.
11-10-2022, 12:45 PM | #33 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
Okay. Will give it a go. Thanks.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
11-10-2022, 07:45 PM | #34 | |
Looks I do not have enough CF roll in the garage to do both my strips. I looked up the product you used and it shows only good for interior use only? Sent from my iPhone using Tapatalk
2010 2LT/RS
11-13-2022, 09:57 AM | #35 |
Drives: 2012 camaro ss Join Date: Sep 2018
Thanks, I ended up doing my roof in same Carbon fiber also!, Did you get yours done yet?
GPI Powered
11-13-2022, 10:12 AM | #36 | |
VViViD Tek R Full-Gloss Black, Highly Weather-Resistant Vinyl Wrap Film Roll (17.75in x 5ft) 4.2 out of 5 stars 1,264 $15.99 $15 . 99 Save 20% when you buy $99.00 of select items One-Day FREE delivery Tomorrow, Nov 14
GPI Powered
11-20-2022, 06:21 PM | #37 | |
Gen 5 Roof moldings
Well I went ahead and purchased this roll and sure enough my worst fear came to realization… the plastic is brittle and broke. The clip attached inside broke as well as the front of the strip on the passenger side, while ever so lightly lifting it with a plastic trim removal tool. I also looked at the drivers side and see the rear is already cracked without even touching it. Looks like I will have to order two new strips. Sent from my iPhone using Tapatalk
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. Last edited by SummitWhite11; 11-20-2022 at 07:04 PM. |
11-20-2022, 06:22 PM | #38 |
Gen 5 Roof moldings
Another pic… also I noticed when pulling the entire strip off it is indeed once piece. Not three pieces as stated for earlier models and later updated to a once piece strip… hmmm???
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. Last edited by SummitWhite11; 11-20-2022 at 06:35 PM. |
11-20-2022, 07:06 PM | #39 |
I did a search via google and trying to find the correct part numbers for left and right strips. Will the clips come with the strips or is this a separate part number? I’m going to go ahead and replace everything with new parts minus the paint. Any help is appreciated.
2010 2LT/RS
11-21-2022, 01:21 PM | #40 |
Drives: 2010 Synergy Green Camaro 1LT Join Date: Jun 2019
I have replaced mine . The clips are separate. You shouldn't need the clips, cause they are like super adhered to the body. The strips are just press fitted on there with the 2 clips at the front and back. The strips change out in literally 5 mins.
11-21-2022, 02:25 PM | #41 | |
One of my clips broke as you can see in the pic. Sent from my iPhone using Tapatalk
2010 2LT/RS
11-21-2022, 08:32 PM | #42 |
They use to be manufactured as 3 different pieces (the middle and the two ends) and the ends are glued on after manufacturing. The glue would eventually fail causing the ends to come off as you've seen.
