03-25-2013, 04:37 PM | #29 |
Drives: 2011 2SS Silver Ice Metallic / BLK Join Date: Mar 2013
Working in the "racing industry" I can add this:
Race teams spend more time purging tires to remove moisture than anything. They use a hydrometer to measure the moisture content in the air in the tire. It normally takes 10 times of filling the tire with pure nitrogen and purging to achieve the lowest number. They are seeing temps in the 250deg range on a typical short track which does make pressure build an issue. I HIGHLY doubt any of us push our cars hard enough to build up that much tire temp. Long story short.....Reg air is perfectly ok. |
03-25-2013, 07:00 PM | #30 | |
Drives: 2013 VR 2SS RS Join Date: Sep 2012
03-25-2013, 07:17 PM | #31 | |
Drives: 2010 VR 2LT/RS A6 Join Date: Feb 2013
This is great and...
Kudos to you sir
Its not how fast you go, but how you go.
03-25-2013, 08:26 PM | #32 |
stubborn as a ...
I stopped to look at some Camaros in a dealer lot last month and the dealer was upcharging $300 for nitrogen and wheel locks. I guess if you don't know any better...
03-26-2013, 06:58 AM | #33 |
Drives: 2011 Camaro LS Stripper model Join Date: Feb 2011
From working at a tire shop for three years now I believe have a very dry air source is more importat than pure nitrogen. We haven't sucomed to the nitrogen salesman yet. I personaly just perfer my extra dry blend of 70-78% nitrogen and oxygen. You should see the standing water in so many tires we remove. Also wrecks havoc on the tpms monitors.
