01-21-2020, 11:15 AM | #29 | |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
Again, lets have people with this set-up chime in with more information. Thing is, that I would not like to impair the emissions requirements, by deleting the CATs and potentially fail smog tests. Regarding intake: The stock inbox can be modified (I.E. Drill openings at the bottom): i would like to remain with a panel filter too - There has been no significant (if any) gains proven by using a conic/round shaped filter (I.E. K&N, Rotofab, Etc.). Ported TB is already installed BtW (Soler) |
02-11-2020, 03:20 AM | #30 |
Drives: SS 6 speed of course Join Date: Jan 2016
just to finish up on the LT1 cam vs the LT4 cam. I check the LT5 cam specs and it is a DoD delete LT1 cam. exactly: 200 /207 .551 / .524 LSA is 116.5
http://www.superchevy.com/how-to/eng...ed-c7-zr1-lt5/ So the LT1 cam is a better factory performance blower cam.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
03-19-2020, 01:10 PM | #31 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
oldman: Verrry interesting...would not have guessed. Thanks for posting.
03-19-2020, 11:57 PM | #32 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
https://www.facebook.com/AdvancedMod...type=3&theater
__________________________________________
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 03-20-2020 at 08:26 AM. |
03-20-2020, 02:37 AM | #33 |
wow on that little blower...
03-20-2020, 04:15 PM | #34 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
Well yea - its 20lbs of boost, with a ton of meth and a ice box for the intercooler to chase the heat away.
I run a Alky meth kit and think it is definitely the way to go, especially with a PD blower, but when the sun goes down - the pump is just a $35 motor from a jacuzzi. If you are that meth dependent, it is a grenade waiting to happen.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
03-20-2020, 05:26 PM | #35 | |
03-20-2020, 07:36 PM | #36 | |
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
03-22-2020, 09:05 PM | #37 | |
20lbs on the 1.7 makes a tremendous amount of heat. They are chasing the heat away with the meth and the ice, but it is not a setup you can rely on under boost on the street. On the track where there is a lot more predictable variables it can be planned for - but you will need to put a meth pump in that thing on a regular basis to make sure you dont grenade it.
