#29 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Blk/Blk 2018 Sierra SLT Join Date: Dec 2006
Bump for an answer
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6 |
#30 |
![]() Drives: 2010 Camaro 2SS/RS ABM Join Date: Jun 2009
Bump
2SS/RS/M6 | ABM | White Stripes | Black Int
Mods: American Racing Headers & Exhaust, Airaid Intake, Pfadt Front/Rear Sway Bars, Stealth Bulbs, AAC LED bowtie, AAC Concept LED Side-markers ABM/Tinted, 20% Tints, Chuck COW Tune, MGW shifter (blue with white racing stripes). Coming Soon: 4:10 Gears? |
#31 |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
The MAF signal is probably the single most important of all the sensors connected to the computer.
The air that passes by the MAF should be smooth, there should be no turbulence, and should be consistent throughout the pipe, meaning more air flow should not hug one side of the pipe missing the sensor. Mass air Meters need to have several inches of pipe before and after the sensor to produce clean smooth readings. Mass Air Meters are extremely sensitive and will measure turbulence as air flow when it may be more or less than actual air flow. The MAF signal is directly responsible for Selecting the appropriate injector pulse width and Timing, calculating torque, and engine load. If the signal is erratic then timing and injector pulse width is erratic causing what guys call bucking. When I ran my Cold Air Test I reported this to a small extent. Also CAIs that have high Fuel Trims will also select wrong injector pulse width and timing, and load values and calculate torque wrong, especially important for A6 Cars. Ted.
www.jannettyracing.com
#32 |
![]() Drives: 2010 SS Camaro Join Date: Mar 2010
But the Vararam doesn't require a tune IF??
2010 SS Camaro/6.2L-V8
Magnaflow Competition Series Axle-Back, Vararam Air Intake, Black bow ties, tinted tailights and side lights and reverse lights, Blacked out head lights, brushed super sport fuel door, blacked out SS logos front and rear. Boss 339 Black Rims with Red Bezel. Next: American Racing Headers, Vengeance Stage III Cam. Red halos Last: Vortech V-7ysi Supercharger, Body kit |
#33 |
![]() Drives: 2010 VR 2SS/RS A6 Join Date: Oct 2008
Ok OP.....Maybe I missed it but what is the solution to this issue YOU have brought to OUR attention?
Intelligence plus character that is the goal of true education.
BrianC. :flag2: |
#34 | |
Can the "bucking" cause damage?
#35 | |
Yes it Shakes your Brain and drives you crazy.
#36 | |
#37 |
Drives: 2005 Pontiac GTO Join Date: Jun 2009
There is really no such thing as a "No Tune Intake" Anytime you are changing the flow characteristics of your intake tract it is going to throw your MAF Calibration off.
Just some will give smoother MAF readings then others (Has nothing to do with the tune) |
#38 | |
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man Join Date: May 2009
I just ordered a Cold Air Industries cai based on your test. These problems that everyone is talking about, is this on all CAI or just select ones, will I notice any problems with this intake. Thanks John |
#39 | |
CCOTR Member
Drives: Victory Red 2010 2SS/RS A6 Join Date: Jun 2009
Ted, do you beleive this MAF issue to be present on the Vararam ? I know you have seen and tested them. What are your thoughts on it?
Camaro Club Of The Rockies (CCOTR) Check us out on Facebook!
--------------------------- 2010 Camaro SS/RS Victory Red A6- Vararam Intake, Doug Thorley Tri Y LTs, Magnaflow X-pipe, Flowmaster Super 40's, VMS Tune, Razzi Ground Effects, Herritage Grill, RED headlight and fog light Halos, LED DRLs, Dash and extended Door ABL, engine, grill and rear defusser LED lighting ........ 12.59@112.21 (DA Corrected) |
#40 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
With a cold air intake, and a hand held tuner like a Predator, what would you look at in the diagnostic data while it is idling to see if your MAF readings are good?
And then if a bit out of whack, is there any of the adjustable items a user could tinker with - or is that done strictly through custom tuning? |
#41 | |
The shorter the MAF Pipe and the closer to the TB the bigger the Problem. Every time an Intake valve opens it sends both a Pressure wave and sound wave back up the intake manifold, and if the MAF is too close to the TB it sees it as both positive and negative air flow, generating what looks like erratic MAF signals affecting driveability. Ted.
#42 | |
Ted.
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) | raptor | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 14 | 06-02-2020 12:51 PM |
DIY: Vararam CAI Install with Color Photos | Jeanius | Camaro DIY & HOW-TO instructions & discussions | 22 | 05-26-2015 02:48 PM |
