05-29-2011, 10:40 AM | #29 |
I just read this whole thread and thanks camaro 1 for clearing up the total confusion, it was funny how everyone could not comprehend what you were describing. and as far as the idea of not fooling with this for 100,000 mi. does not compute for me at all. I will not wait that long to service my trans, plus what if someone puts a trans cooler or swaps out the radiator for a heavyduty be-cool radiator, and has to undo the trans lines and loses fluid like I'm about to do. I do apreciate the op for trying to share but if they dont know what there doing they should not write a diy post. thanks again to camaro 1, great write up.
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s. |
05-29-2011, 11:31 AM | #30 |
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
I am going to get one of these kits so I can fill/check the trans fluid.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop Rx Catch Can;Rx Breather;Roto-Fab Washer Container VMax Ported RJT Throttle Body XSPower Headers and XSPower 3" Exhaust System Elite Engineering Tunnel Brace, Gorilla Wheel Lock System; Bear Rotors, Hawk HPS Tinted Windows 35%;EFILive Tune |
06-22-2012, 07:18 AM | #31 |
White 2ss, LT, CAI, Tune
Drives: 2010 L99 Join Date: May 2011
whats the torque speck on the pan bolts???
06-22-2012, 09:14 AM | #32 |
If you are going to take the time to change the fluid why not just drop the pan, get all the fluid out, clean the pan and magnet and change the filter. I upgraded my filter. This one has a pick up opening almost twice the size as OE. This eliminates any pump cavitation at high RPM.
Stock Filter. Upgraded Filter This is what I use to fill 6L80E's. You fill the bucket, then pump the handle. It pressurizes the bucket then will fill the trans. Much easier than doing it one quart at a time. It also comes with various adapters for different filling locations. |
06-22-2012, 09:41 AM | #33 |
Drives: a Panty Dropper Join Date: Feb 2012
What about the fluid in the tq converter doesn't the car needs to be running to circulate that out.
06-22-2012, 10:04 AM | #34 |
You would need a fluid exchange machine to get all the fluid out of the converter. It is still important to clean the magnet in the pan and change the filter.
06-23-2012, 05:27 PM | #35 | |
Thanks. Bill
02-06-2013, 12:24 PM | #36 |
yea same question on the upgraded filter.
actually correct me if im wrong but is it a Circle D filter? seems like it is but i cant seem to find where to buy it. |
08-16-2013, 10:30 AM | #37 |
Drives: 2010 Camaro SS Join Date: Mar 2012
My god just go to a dealership people, its a once in every 100k job!
Maxima SE (Traded) Camaro SS Hummer H3 |
08-16-2013, 06:13 PM | #38 | |
Bill
09-09-2013, 03:06 PM | #39 | |
aka Patrick
It is only recommended once every 100k miles... but spirited driving or towing (for towing vehicles) needs changed around 40-50k miles... Depends how the vehicle has been driven and what temps the transmission fluid has suffered through. I've seen burnt trans fluid on cars with less than 35k miles on them. I prefer to keep my car in excellent condition and change diff & trans every 10k miles.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft |
09-09-2013, 04:48 PM | #40 |
Ditto....
03-15-2014, 09:17 PM | #41 |
Drives: Cyber Gray 2LT RS Join Date: Aug 2011
Is it possible to do this to these camaros? http://www.google.com/url?sa=t&sourc...62922401,d.b2I
03-16-2014, 12:53 PM | #42 | |
Good luck. Bill
Similar Threads | ||||
Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 09:17 PM |
Whitmoyer Chevrolet..CAMARO BLOW OUT!!! GM PREFERRED PRICING OR LESS!!!..Pix Inside | Matt.Beaver | Dealer Camaros for Sale | 6 | 04-09-2010 01:27 PM |
Master list of in stock/inbound Camaros @ Rockmont | Frank in MD | Dealer Camaros for Sale | 19 | 03-10-2010 05:17 PM |
Sealed Transmission?? Transmission fluid doesn't need change until 150k miles? | DevilKnightFalcon | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 34 | 12-07-2009 06:32 PM |
