04-16-2022, 07:30 PM | #29 |
Drives: 10'ss/rs Join Date: Nov 2013
Thanks ,That part helped me the most .I finally finished and it sounds a lot better. Like you said it sounded good before the amp. I might need more fine tuning on the dash speakers they did not like much gain at all. But I will play with it some more. Been a long day ,Lol. Thanks for all the help once again.
04-17-2022, 04:22 PM | #30 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Matt Miller
2020 SS 1LE |
06-21-2022, 05:27 PM | #31 | |
Drives: 2022 ss1 1le Join Date: Mar 2022
I'm very happy with the upgrade for the ~$270 I put into it. I'm curious about an amp but I get that its alot more work to splice into the harness, run wiring and fab some brackets so I plan to leave things as they are for now. |
06-21-2022, 08:24 PM | #32 |
Running wire to the front from amp wasn't to hard. I just had to do it twice because i had no clue how to hookup a amp . Once i understood how to wire amp it was not bad . Bracket was simple piece of abs plastic and some screws ,put on top of mag ride computer . Wish I would have went with the kicker amp . I used Alpine kta 450 , its ok i guess but I cannot turn up front gain hardly at all and rear gain not at all without bad distortion. Amp definitely worth doing however. Upgrading the speakers and everything made a great car even better .
06-22-2022, 08:42 PM | #33 | |
03-30-2023, 12:10 PM | #34 |
Drives: you nuts Join Date: Nov 2022
Door Chimes and Active Noise Canceling (1SS)
I've read in other threads when changing speakers and adding amps to 6th Gen:
03-31-2023, 08:10 PM | #35 | |
It doesn't seem to apply to mine, but remember it has no external amp at all whereas a non-1LE SS has an amp in the trunk. I don't know how that affects things. Also, I have the gain on my little Kicker amp nearly at the lowest setting. That obviously makes a difference.
Matt Miller
2020 SS 1LE |
04-03-2023, 11:19 AM | #36 |
@Msquared I should have mentioned both my questions apply to 1SS 1LE. Your answers are clear. Thanks!
04-04-2023, 08:38 PM | #37 |
Drives: Wild Cherry LT1 Join Date: Dec 2016
A couple things to add to this thread. Firstly big thanks to Msquared, there’s no way I would have figured out how to remove those pillar bungees without his posting pics and describing what needed to be done to release the tab.
I increased the volume and clarity of my front speakers without the need of an amp. JBL’s are very efficient and relatively inexpensive. So, I sent the Amp back to Amazon. With that said, I have a new under dash break out harness (will no longer be using it) So, hit me up if you’re interested in buying at a discount. One of the areas I’m disappointed in is how the door panel basically blocks 60% of the open area for bass to pass through. There’s a noticeable difference in sound quality with the panel on verse off. The next thing I noticed is the door panel decorative boomerang now vibrates a bit with certain frequencies and volume levels. I’d definitely recommend adding flocking tape under the boomerang near the speaker, while you already have the door panel off. |
07-07-2023, 11:12 AM | #38 |
Roksn1fR
Drives: 2023 1SS 1LE ShadowGrey Join Date: Jul 2023
Hi everyone, perhaps someone can provide guidance. I just got my new 2023 SS 1LE a few days ago and i just love it ! However I admit I am kind of disappointed with the sound system (I previously had a 2013 SS w Boston acoustics which was great for me). Therefore I'd like to upgrade to something better but not too extravagant. This current post and others (https://www.camaro6.com/forums/showthread.php?t=611186, https://www.camaro6.com/forums/showt...=586969&page=2) contain amazing tips and walkthroughs but I am kind of a noob wrt car audio connections. I was wondering if anyone would recommend a specific car audio shop that is used to deal with Camaros SS 1LEs so i can get the sound pumped up a bit with a reliable install ? Any suggestions ? (anything in west Houston, TX is even better ). Thanks a lot !
#2023 1SS 1LE ShadowGrey - M6 - Stock - Diode Dynamics Smoked Sidemarkers / Zl1 Addons Deluxe Rockguards & LiftPads / EOS Carbon fiber center console gearshift cover / Elite SS License Plate Frame / 1st stage Paint Correction after factory delivery / Paint Protection Film (front bumpers and fenders) / Ceramic coating
#2013 1SS RS Victory Red / Hockey+COPO Stripes - M6 - Stock - SOLD #2012 2LT RS Blue / Racing Stripes - M6 - Stock - SOLD |
07-08-2023, 05:37 AM | #39 |
Drives: Subaru WRX Join Date: Apr 2019
Just wanted to say thanks for this write up. I just got a 23 1ss 1LE and this has helped to explain all the questions I had about the gen5diy harness and getting to everything.
I already have the helix m6 dsp amp for highs and helix m one for bass do I will be sticking with a two amp setup and 2 12s but this really clarified everything so well for me. Thanks again! |
07-09-2023, 04:35 PM | #40 | |
Drives: 2023 Camaro LT1 M6 Join Date: Dec 2022
This is the main issue I'd like to get fixed on my LT1 w/Bose and would try a speaker upgrade if that can help this without going into the full new amps swapout (and big $$) approach.
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers |
07-09-2023, 04:46 PM | #41 |
Curious how you made the stand for the amp, looking to add just a subwoofer to the stock system for the time being. Not sure where else to hit the amp. Thanks!
Edit: I wonder if I could make this work. GM GENUINE PARTS RADIO SPEAKER AMPLIFIER BRACKET GM Part # 23401119 ACDelco Part # 23401119 https://parts.gmparts.com/product/gm...=432&year=2019 |
07-09-2023, 08:08 PM | #42 |
If you're asking me, I just used a flat piece of ABS plastic and drilled three holes to match the holes in the MRC module bracket that are already threaded for the stock 2SS or Bose amp. For small and light amp like the Kicker KEY, that's plenty. If you want to use a bigger, heavier amp, then it may make more sense to remove the styrofoam tool kit and inflator holder and mount the amp in that part of the trunk floor.
Matt Miller
2020 SS 1LE |
