10-24-2013, 08:27 AM | #29 |
Here a interesting thread I am following on the new heartbeat for the LSA and discussion about the blower size. http://www.ctsvowners.com/forum/show...alled-on-CTS-V
10-24-2013, 12:52 PM | #30 |
Drives: 2013 zl1 Join Date: Nov 2012
How big is this maggie
2011 cts-v coupe (pinky) wifes car.. ls9 cam c.a.i. 11.44 2007 corvette vert ..retired.. 2013 zl1 stock blower stock ci 20" wheels 10.36 135...so far.. |
10-24-2013, 01:13 PM | #31 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
It is a 2.3. Andy at ADM told me he has installed them and it is not as good as the LS9 2.3. That thread information is being posted by a Maggie engineer so it is hard not to be biased.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
10-24-2013, 01:45 PM | #32 |
The kb is 7049.00. The big kb
10-24-2013, 03:46 PM | #33 |
Drives: 2013 TT ZL1 Join Date: Jun 2013
ZL1 with twins
10-24-2013, 09:23 PM | #34 |
Drives: 67, 68, 88, 98, 10, 12 ZL1 Camaros Join Date: Dec 2008
10-24-2013, 10:29 PM | #35 |
3.6 is supposed to be a bolt on .. its either this or a rear mount compound setup. Iv decided.
10-25-2013, 02:29 AM | #36 | |
Thread Mover
Drives: a Monte Carlo Join Date: Apr 2011
Idk about the 5th gen Camaro but the Ford guys have a few different ways of getting these to fit under stock hoods. Maybe the same can be done, that is if it even needs it.
In the market for something fast |
10-25-2013, 08:11 AM | #37 |
SLOBRA1
Drives: GT500/Cruze/DMax/Cobra Join Date: Feb 2012
Sadly the 3.6KB doesn't fit under the stock Shelby hood. Even with lowering the engine you need a different hood, unless you already have a Super Snake.
2010 GT500 Best ET=10.10 - Best Trap=143.59mph
2003 Turbo Cobra Best ET=8.27 - Best Trap=166.42mph |
10-25-2013, 11:50 AM | #38 |
Speed Freak
I don't know if you went through pricing all of the components you need to swap to LS9 2.3 but it actually not that much differnt in pricing. You need the entire LS9 lid and components or it will not flow and those parts are much more expensive than a 1.9. The conversion snout is $1.5K and the 102mm TPIS throttle body (is a must) is $1K. By the time you adjust the pulleys you are in the same price range.
In case you can't tell I want you to do the test on the KB since I already went through the 2.3. I could not keep the 1.9 cool on the road course so something had to change and backing off the power a ton just was not an option for me. Keep us posted whatever you decide.
10-25-2013, 12:25 PM | #39 | |
Drives: 18 ZL1 A10 & 18 2500HD Duramax Join Date: Oct 2012
Procharged 2018 ZL1 A10
2018 2500HD Duramax |
10-25-2013, 02:47 PM | #40 |
Thread Mover
There's a few SVTP members who have been able to get it under the stock hood, and Lethal has a 4.5L Whipple under the stock hood as well.
10-25-2013, 03:16 PM | #41 | |
SLOBRA1
Straight from my builder and Van... Feel free to pm me a build with a 3.6kb under a stock Shelby hood so we don't clog this thread up too much. I'd like to see how it was done. Update: Truck Norris is correct about the stock hood fitment. I'd still get an aftermarket hood instead of the engine drop that is required.
2003 Turbo Cobra Best ET=8.27 - Best Trap=166.42mph Last edited by islander033; 10-25-2013 at 03:50 PM. Reason: Truck Norris is the man. |
10-25-2013, 03:29 PM | #42 |
I don't know where you got all your 2.3 stuff from but that is NOT the way to do it on one of these cars
the 2.3 lower itself is 2800 from pace performance. the stock zl1 lid and brick are MUCH more efficient and can be used. the blower must be taken apart and the outlet cut out and a new outlet with correct fitment for the zl1 intercooler brick welded in.. its not something the guy in his garage can do but it is a easy task to have done. The snout can be modified by removing the shaft and the shaft shortened. I can do a ls9 blower for about 3500... but I honestly don't think it will put me where I want to be.. the 3.6 KB will fit if your willing to cut the waterfall out from the stock heat exchanger SOPPOSEDLY.. if I buy a KB and have to install a carbon fiber hood or a copo and that's the only problem, id be happy.
