#29 |
I run 2 catch cans...
Normal. If you want clean, install hi-flo cats.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
#30 |
![]() Drives: 2011 2SS Convertible Join Date: Apr 2014
I have hi-flos on mine with headers and tune and still get the same thing. I could clean them after every run (and do so it's easier to keep clean). I always wondered the same thing....why? I'm going to check my CAI filter and it's a 2011 so maybe new plugs?
#31 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
The only "problem" is the tips are flared out and soot is noticeable....Every exhaust pipe looks like that on the inside...Quit looking at it, and the problem is solved...
It's like wondering why water is wet. |
#32 | |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
I've had a catch can on mine for 4 1/2 years and it has never even been mentioned over many service visits.
The Bird is the word! |
#33 | |
![]() Quote:
#34 |
5th Gen DI V6 engines are pretty filthy.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
#35 | |
![]() Drives: 2019 Corvette Grand Sport Join Date: Dec 2014
#36 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
I'm tuned but I understood my risks before I took the plunge and accepted them. |
#37 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
I mean don't some of the models above the SS come with a catch can from the factory?
#38 | |
There have been many instances of oil pump failures and GM knows about it. http://www.camaro5.com/forums/showthread.php?t=72458 I definitely would have made them explain how it caused the problem and put it in writing. Many people just accept what the dealer says and do not force the issue.
The Bird is the word! Last edited by Angrybird 12; 05-06-2017 at 08:21 PM. |
#39 | |
The burden of proof still falls on the dealer/manufacturer. BTW there are many threads in Camaro5 explaining this, so I am not making this up.
The Bird is the word! Last edited by Angrybird 12; 05-06-2017 at 08:14 PM. |
#40 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
It would be up to you to prove the modification could not cause an issue, and you can't.
2011 1SS/RS LS3 CGM
#41 | |
If what failed is a known issue and you have proof that it is a known issue such as a TSB number it is hard for them to use that excuse. Here is a good explanationo on the steps you should take if you are denied a warranty claim due to a mod. http://www.semasan.com/page.asp?cont...enied&g=semaga
The Bird is the word! Last edited by Angrybird 12; 05-06-2017 at 09:56 PM. |
#42 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 camaro Join Date: Feb 2012
anytime you burn something, anything, you get carbon. normal. hell, all gasoline is, is 8 carbon atoms bonded together.
