#519 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
#33 towards the front of the car.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
#520 | |
H-Town Camaro Club
Drives: 2010 Black Camaro 2LT RS M6 Join Date: Apr 2010
Never mind - I found an earlier post - in case anyone else wants 'constant' power, the link is here: http://www.camaro5.com/forums/showthread.php?t=135406
#521 |
DAP-ONE [COTW - 12/23/13]
#522 |
Emerald Coast Camaros
Drives: '12 2SS/RS LS3 GBA Join Date: Sep 2011
I literally had no idea what I was doing but I'm done and it looks awesome! It was kinda fun trying to figure it all out and after I changed some wires around and everything lit up I was screaming happy joy!
#523 |
IN THE CIRCLE
Ive read this thread many times.
I have everything needed to do the mod. For some reason Im scared to try it though. |
#524 | |
buzzy56
jump in
Well worth it !
#525 |
![]() ![]() Drives: . Join Date: Nov 2010
Wish me luck! Going to install the AAC foot well LED strips (ABL Color) tomorrow in both of my Camaro 5th gens. Using the passenger side kick panel "gray" wire method rather than contorting myself to the orthopedic surgeon with the under dash gig. Installed the ABL color LED's in the dome and trunk so far, liking the color for entry/exit...matches the stock dash and door ambient perfectly, looks sharp. With the under dash ABL LED strips wired in to match the performance of the theater dimming dome this should be killer. THEN, afterwards, it's a switchable LED installation for cup holders, ambient/accent interior lighting using the Oznium LED's.
#526 |
Camaro CRAZY
I installed mine but I want them to come on with my dome light and I also want to be able to have them on or off while driving via the switch provided by AAC.. What part am I missing? Currently I can only get them to turn on and off if the dome light is on. I have a SPST switch just need to know how to wire that. I have the lights on 1 prong, ground on 1 prong, and the grey wire on 1 prong. Where would I put the wire from the cigarette lighter for constant power? Does your key have to be in the ignition for the power to the cigarette lighter to be working? Thanks!!
#527 | |
![]() Drives: 2012 SS (2SS/RS, M6, IOM/Blk Rally) Join Date: Aug 2011
1. I ground my footwell lighting like explined in the first post of this thread. 2. Footwell lighting goes to the center prong on the SPDT switch 3. Left prong to dome lighting. 4. Right prong to my traction controll yellow wire. I am at work right now but I still have all the packaging at home. I can list the part numbers when I get home if you would like.
In your next picture post, DIY guide, or advertisement thread take a moment and think of the color blind guy. Thanks. |
#528 |
Camaro CRAZY
I wonder if they have round switches like that. I've already drilled a hole the size of the AAC switch...
#529 |
![]() Drives: 2011 CGM 2SS/RS Join Date: Apr 2011
I also used the SPDT toggle from radioshack to wire my footwells/rear seat/grille/puddle lights to both the dome and cigarette lighter. For the cigarette lighter to be powered, the ignition does need to be in the on position.
If you wanted the rocker type switch, Oznium has one at http://www.oznium.com/rocker-switch though I'm not sure if the diameter would match AAC's |
#530 |
Got mines done over the weekend! I never would have known to tap into the correct wire if it werent for this! Thanks so much!
Instagram @Tavo_32
#531 |
Camaro CRAZY
Pharmaro how did you use that switch with the cigarette plug and everything. I have one of those switches already it just doesn't have enough poles for how many wires I've got.
#532 | |
Camaro CRAZY
So your switch doesn't have a ground wire going to it? Just the lights are grounded? If that's the case then all I have to do is tap into the cigarette lighter plug and switch the ground wire to the LEDs instead of the switch. |
Where to wire in ambient footwell lighting? | cybercoaster | Cosmetics and Lighting Modification Discussions | 32 | 01-11-2016 11:08 AM |
Anyone have the Footwell Lighting Kit Installed? | wildthing001967 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 12 | 07-03-2011 05:00 PM |
AACStyle footwell lighting problem | TRSS2 | Camaro DIY & HOW-TO instructions & discussions | 8 | 01-23-2010 06:41 PM |
footwell neon lighting. How to wire to have it come on the other ambient lighting? | Jakefeb3 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 6 | 11-22-2009 09:32 PM |
