08-18-2014, 12:59 PM | #43 | ||||||
Drives: none Join Date: Aug 2011
With the shifter in D, it doesn't downshift from 2 to 1. M does. It's actually 200rpm. 5800ish in D and 6000ish in M. Quote:
Still though....HIGHLY doubt it. Also...hope you're wrong so that my 11.0 car isn't getting beat by a stock Hellcat on a tire. Quote:
Another forum member had his car dyno'd recently and bone stock he made 55 or 60 rwhp less than a normal A6 ZL1 made. And it was on the low octane map. |
08-18-2014, 01:23 PM | #44 |
Drives: 2015 SS Sedan M6 Join Date: Dec 2009
my point was that there are in fact people that believe putting in 87 octane in a car that requires 91 or above is not a problem. I hear people all the time saying "oh well my car sounds just fine with 87"
08-18-2014, 01:32 PM | #45 |
Drives: 2013 ZL1 Join Date: Oct 2013
I remember mine shifting 500 early.. I will have to check this weekend
2013 Silver ZL1
08-18-2014, 01:42 PM | #46 | |
Drives: 2013 ZL1 Join Date: Oct 2011
talking smack about a 9.8 car when you run 11.3??? that is just retarded. 55k+20k in mods =75k car running 9.8's and you say that is pathetic. go run 9.8's for less that 75k then come back and talk. telling someone to just sell a car is your solution???
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
08-18-2014, 01:46 PM | #47 | |||
CamaroFans.com
08-18-2014, 01:51 PM | #48 |
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
I am one of these guys that leave the car running, here's why. I monitor my iat2's with aero force gauges. If I make a run and get back into the staging lanes and push my car up the line (shut off)for 20 min by the time I run all that heat has migrated up into my supercharger.
When I start the car my temps are at 58 to 60Celcius. HOT enough to pull timing and doesn't have enough time to cool down before I make a pass. If I idle the car up my iat2's stay around 40 to 42Celcius when I pull up to do a burnout. Under no boost idling the pump is circulating the intercooler coolant and my engine fans are drawing air through my heat exchanger. I've data logged my car several times and it will pull timing if I shut it off in the staging lanes
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
08-18-2014, 01:54 PM | #49 |
My self too.. I pop the hood, let it cool between runs.. A little effort to keep them cool goes a long way
2013 Silver ZL1
08-18-2014, 01:57 PM | #50 |
ANGRY Z
I open the hood also but let the car idle
08-18-2014, 02:00 PM | #51 |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
If you have HP Tuners you can also turn the blower coolant pump on with just the key in the on position. Same for the engine cooling fans.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
08-18-2014, 02:02 PM | #52 | |
Drives: '13 Roush S3 '16 Ram Sport 4X4 Join Date: Apr 2009
Maybe the previous owner had some mods and took them all off and didn't have the original tune back to stock? Maybe it's a tune thing? Either way, that should not happen at all. Good luck going forward and keep us posted on your solution. |
08-18-2014, 02:07 PM | #53 |
ANGRY Z
That's my next step and would be a better option than idling
08-18-2014, 05:20 PM | #54 |
Glue Mkr
Drives: 1999 Super Sport NBM, 2013 ZL1 BRM Join Date: Aug 2014
Thanks for all the input, I will continue to do the little things like the fuse reset, and continue to put the higher octane fuel in it. Maybe I just need more time to play around with her.
2013 ZL1 aka (GLUE MKR) No Mods Yet..... 1999 SS aka (SUPA SLW) Comp cam, Few bolt on's. |
08-18-2014, 08:24 PM | #55 | |
Snake Eater
Drives: 2012 AGM ZL1 Join Date: Oct 2011
I wasn't trying to bash you but maybe dyno to see if all your power is there because I do see people from time to time posting low dynos even on YouTube and I know it's not normal Sent from my iPhone using Tapatalk
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ Follow me on instagram: http://www.instagram.com/snkeatr/ |
08-18-2014, 08:32 PM | #56 |
Drives: 2013 Black 2 LT vert Join Date: Jul 2013
OP. i am baffled too . logic would seem like your new ZL1 would outrun the older camaro. what is the HP rating on your 99 SS, like 320? if i recall, the base z28 then was like 305 and the SS ram air was 325, at least in the trans am. the 99 is lighter than your ZL1 too. also, what is the gearing comparisons too? but, i have to agree, you shouldnt have to do anything to the car for it to outrun the older car. just seems strange to me too.
