12-05-2023, 07:36 PM | #43 |
Drives: People crazy with my sexiness Join Date: Jun 2023
Yeah steering wheels are weak points. Usually hallow aluminum tubes. Any half sharpened hack saw from Lowe’s will cut one open in about 5 seconds.
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023 2024 2SS 6MT coupe Sharkskin/Light gray Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers Gray painted split spoke wheels Illuminated footwells/illuminated bowtie |
12-05-2023, 08:44 PM | #44 |
Drives: Camaro Join Date: Jun 2023
12-06-2023, 08:25 AM | #45 |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
Something like this pedal lock box isn’t pretty but might take longer to defeat
https://youtu.be/KFkOyVsdJkE?si=d429aH1P_dBhCxPT |
12-06-2023, 03:47 PM | #46 | ||||
Electrical Engineer
Drives: 2023 1SS A10 Black Join Date: Apr 2022
This is from the kill switch thread:
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
12-06-2023, 05:28 PM | #47 |
Drives: Wild Cherry LT1 Join Date: Dec 2016
I’m going the simple route that would hopefully scare someone off before they actually get in the car. It's mainly fun car with the occasional road trip.
I use this system for my three sheds. The switches and the horns all linked to the same remote(s). The horn is loud as hell and should scare the bejesis out of someone that thinks they have a nice clean entry. https://www.ebay.com/itm/20391820434...BoC6QkQAvD_BwE The switches are battery operated and will need to be changed from time to time (I’ll do that during oil changes). I’ll end up tapping the 12 VDC that’s feeding my amp (just because it’s easy access) for the horn. The horn will be either zip tied or Velcro’d under the dash. It looks like the sensors and magnets can be placed just under the dash edges and on the doors. I’ll probably end up removing the magnet housing and painting the sensors flat black (or wrapping black). The antennas don’t need to be extended. They have great range retracted. I’ll Velcro the remote inside the trunk. While this solution may not be for most, I figured I’d share. For the $ and effort it works for me. |
12-06-2023, 05:42 PM | #48 |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
I recently purchased this plug-and play remote switch and am going to substitute for a fuel system fuse as a critical system cut off. As soon as I can confirm it works 100%. I will give the heads up.
12-06-2023, 05:44 PM | #49 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
12-06-2023, 05:51 PM | #50 |
Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
12-06-2023, 05:56 PM | #51 |
This
12-06-2023, 05:58 PM | #52 |
12-06-2023, 06:14 PM | #53 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
24 2SS 1LE, Riptide Blue, A10, PDR. Picked up 11/5/23, 560 miles.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
12-06-2023, 06:15 PM | #54 |
12-06-2023, 06:30 PM | #55 |
12-06-2023, 06:37 PM | #56 |
