05-22-2013, 05:23 PM | #43 | |
Drives: 2011 Cyber Gray 2SS 6 speed Join Date: Jan 2012
Thank you |
05-22-2013, 05:35 PM | #44 |
Bayou City Muscle Cars
Drives: 2013 2SS Dusk Edition Join Date: Jan 2013
bleh none of them have BlueRay Metallic.
hate having the rare color sometimes.
Lethal Racing Stage V PER 418ci Forged LS3 530/520 SAE |
05-22-2013, 07:30 PM | #45 |
Finally Satisfied
Drives: 2017 Hyper Blue 2SS M6 Join Date: Nov 2009
05-22-2013, 07:36 PM | #46 |
U.S. Army Veteran
Drives: 2LT/RS SGM M6 Polished 20's Join Date: Mar 2011
Well Done!! A great DIY!!
05-22-2013, 07:47 PM | #47 |
Finally Satisfied
06-11-2013, 03:29 PM | #48 | |
Drives: 2013 Chevy Camaro 2LT 3.6 V6 Join Date: Apr 2013
Did you buy white LEDs? or did you buy amber and red? how many strips? |
06-11-2013, 04:13 PM | #49 | |
Both ends have power wires attach so just use what ever end you want and you can trim to the size you need. Just make sure you count in 3's then cut. 1, 2, 3 Cut or 1,2,3,4,5,6 Cut and so on you get it. FYI the back side markers are longer. Do not cut your LEDs with out test fitting them. |
06-12-2013, 05:23 AM | #50 |
Drives: 11 ss/rs RJT w/Black Cherry stripes Join Date: Sep 2010
Nice job OP they came out great
06-12-2013, 07:48 AM | #51 | |
06-13-2013, 10:19 AM | #52 |
When I go to order the bulb bases it makes me select "With Wires (RGBY)". Is this right? dont they only come with two wires?
06-13-2013, 11:07 AM | #53 |
To be honest that is a new option I think. I don't remember having to choose. They come with 3 wires. You should use a volt meter to test what wires go to the 2 wires on the base. It should be the 2 outside ones. (red & Black) It had a white one in the middle and I just cut that one off. You can see it in this pic a little. Hope that helps.
06-13-2013, 11:57 AM | #54 |
OK thank you!
06-13-2013, 11:17 PM | #55 |
Drives: White M6 1LT RS Join Date: Mar 2010
http://www.camaro5.com/forums/showthread.php?t=177650
I did this a while back. I found the Radiantz LED's are much nicer. The spacing between LED's is only 1mm.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
06-14-2013, 07:34 AM | #56 |
I was thinking of doing something a little different like ghosting the word camaro into the paint. Do the LEDs light up the sidemarker evenly or would it look uneven? What do you guys think?
