#43 |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
I see the factory MPH but use Dashlogic to display rpm. I prefer seeing actual numbers rather than a graphical representation that has some lag.
#44 | |
Hide! My wife's coming!
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2011
I believe your correct that you cannot see the factory RPM. This is mainly due to the way the dash logic communicates the data over the onstar system. A lot of the "issues" that are reported are not really issues but rather the way the dash logic functions. With that said, the two issues I had were HP/TQ and Trans temp but with the latest update they had, that fixed the issues for me. If your using an extension cable and experiencing issues, remove the extension and see if the issues persist. I know with the extension cables, a lot of propel experienced issues with the device freezing, not coming on with car is running, etc
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
#45 | |
#46 | |
![]() Drives: 2014 ZL1 White Convertible Join Date: Aug 2013
fellow camaroian. also I am using the extension cable, I might give It a go to see if I get better results without it, although it will not be very practical without the cable imo. |
#47 | |
#48 |
great information, hopefully I get some good results.
#49 | |
![]() Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
#50 |
fuse pull didn't help make the dashlogic initialize on startup. bummer. Does any one else get it to start when the car starts?.
#51 | |
No issues at start. As soon as my car starts, the dash logic powers up. You might want to give Palmer a call. Make sure you aren't using any extension cords. Have you tried plugging anything else in your obd port and see if it powers on at start?
#52 |
I use an extension cord. will yours start up if you use an extension ?.
#53 |
#54 |
no I haven't done that with the nav..
have you gotten it to start without an extension?. |
#55 | |
Dashlogic
Remove the extension and try without. I have seen several threads about different issues because of the extension. I do use an extension and the issue I have which I know is due to the extension is mine will freeze when WOT sometimes.
#56 | |
