11-30-2018, 10:02 AM | #43 |
Drives: Camaro Join Date: Sep 2018
JMO, I'll take the 219 over the 224 @ .050 but would like to see .600 lift I/E max & have the heads flow to match the cam. Just want a good street/strip cam with stock idle rpm.
11-30-2018, 10:39 AM | #44 |
Drives: SS 6 speed of course Join Date: Jan 2016
it would be my opinion, to lose some exhaust to cut down overlap so I would think the smooth idle cam 223/227 is a better smooth cam vs 219/230 or even 224 /236. the Tx Speed smooth idle works a lot better within the parameter of smooth idle, keeps the intake which provides the power and the phaser for "stock like" performance.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
11-30-2018, 11:33 AM | #45 |
Drives: 6th gen Join Date: Aug 2013
The exhaust/intake flow ratio on the lt1 is on the low end, I’d love to keep the dcr up but I’d def want to clear out the cylinder too. Thoughts?
‘22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28” dragpack - 11.68@122
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
11-30-2018, 11:41 AM | #46 |
I think the ugly LT1 exhaust flows well enough.
So for ANY cam posted, one can say a bit more exhaust will add power and help on bleed down. Yep absolutely. Any cam posted will idle just that much poorer for any duration change intake / or exhaust. My point is the Texas speed 223 /227 on 116 is probably a better cam in terms of power than the 219 /230 with the same idle.
11-30-2018, 12:13 PM | #47 | |
11-30-2018, 12:46 PM | #48 |
To clarify zboy was speaking about his tsp stage 2, 232/235
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) Last edited by 6spdhyperblue; 11-30-2018 at 01:00 PM. |
11-30-2018, 05:45 PM | #49 |
that little bit means there is overlap at .050 on a standard 116 LSA...
12-01-2018, 10:48 AM | #50 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
If you are NA and do not want to lose low end torque, a tighter LSA and/or advance ground in will help you. Even with overlap your car can drive pretty darn well. If you are looking to make big power, most of the shops are locking out the VVT cam phasers (0* lockout block) and just relying on the cams valve events. Cam phase limiters can get flaky over time and potentially lead to engine damage.
________________________________________________
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
12-01-2018, 02:08 PM | #51 |
Drives: 2018 2ss 1le Join Date: Jan 2018
So ...
I’d like a cam that: basically idles like stock (small lope only perceptae if listening for it) Makes linear power from 2000 to Peaking at 6500 (not 5800 like stock) And because I’m greedy don’t want to lose any torque And of course more power |
12-01-2018, 02:54 PM | #52 |
Drives: Black Join Date: Jan 2017
Lt1 makes peak torque at like 4100
12-01-2018, 07:44 PM | #53 | |
TxSpeed has a 116 LSA in all flavors that work with their 20 degree limiter for a power peak at 6500 you will need a stage II+ cam so 230 ish
12-02-2018, 09:03 AM | #54 |
If you don't complement your cam with better heads & headers your not going to get all the power out of any cam.
12-02-2018, 09:05 AM | #55 |
I’m thinking I want to get beehives work to keep spring pressure down. Im thinking it will extend the life of the phaser.
Find some soft ramp rates(give up some power) and maybe get some power back from the weaker springs
12-02-2018, 10:45 AM | #56 |
if you are going with DoD, then Cam Motion makes a nice set of beehives to .600 lift. Bout all the pressure the DoD can take IMO, maybe even phaser can take? dunno.
If you are going .600 to .650 then forget the beehive, either go Comp Cam conical or a dual spring setup. If I had the time I would have gone conical. I did not have time and Texas Speed is down my street, so I did their dual setup, which was spec for their ground cam: Pray supercharged, had a cool built in spring seat with valve seal. I do think the Texas Speed cam is going to make more power then duration vs duration than any other cam: 1) they use the 20 degree phaser 2) they have an aggressive ramp 3) they in general have more lift The disadvantage: you better get pushrods, trunions, and change valve springs often, and IMO the phaser is suspect. This is a hobby for me and I'm a worry wart. So if I were to do it again, I'd do a Cam Motion solid gear cam (VVT delete), don't care about the slightly better drivability or a slight power gain (due to both VVT and faster ramp).
