04-26-2010, 01:40 PM | #43 | |
Ted.
www.jannettyracing.com
04-26-2010, 01:48 PM | #44 |
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man Join Date: May 2009
Thanks Ted, I apprecaite the info. John
04-26-2010, 02:16 PM | #45 |
Drives: 2010 camaro Join Date: Jun 2009
Here at VR we call this "noise" , "a weak signal".
There are many factors that can cause this , however there are only a handfull of ways to address it properly. In the Camaro unit - this is a modular unit and as such it is adjustable in many areas. As an example - We are using a short high volume rear runner, this means that volume is high, but velocity is low. We then added MAF spacing for velocity adjustment up to .75 inch putting the MAF closer to the bore yielding a stronger signal for ease of tuning, without greatly altering the MAF scaling. We have also made provisions in the kit for slide in Venturi inserts in the bore , if they were ever needed, again strengthening the signal. Screens act the same as a venturi , most are not thick enouph ( 1mm) to act as air straightening systems ( 3-4mm is needed) what they tend to do is simply make the inlet smaller ( via their area reduction) This boosts velocity ,which makes for stronger low end signal strength below 2000RPM. A tuner would see this as "less Noise" . This will typicaly reduce volume by 30% for a distance of 1-3mm which does not greatly affect peak airflow. There are other ways as well ( plenum chambers, central blades, longer runners etc..) All of the above work , it just depends on the application and the volume required to deliver the power you are after for a particular application. Packaging must also be considered. The Airspeed on an LS-3 engine at 1000RPM is a "as measured" 6.5-6.8 MPH in five locations around the bore ,flush with the TB Bell mouth.Vacuum pressures equalize at 1,200RPM, 1inch in front of the TB blade. The Camaro units we have made for forum members are typicaly set up for that particular cars application in an effort to not have to tune, yet allow them to run long tubes, high flow cats etc... Tune models are -just that, we also work with our dealers to establish the best combination for their customers cars, whether mild or wild. If a stronger signal is needed we have the ability to alter the Camaro unit so that a more radical combination of camshaft cylinder head etc... can be used, yet street drivability and ease of tune will not be affected. This unit unlike the G8 and GTO units, is fully modular, allowing for almost infinite adjustment up to its full airflow potential of 700 cu/inch and 1000HP. VR Tech |
04-26-2010, 02:32 PM | #46 | |
Drives: SuperSport's Join Date: May 2009
2002 Chevy CamaroSS MN6
'08 Chevy TBSS AWD "DD" Plans : 2013 CamaroSS 1LE |
04-26-2010, 02:53 PM | #47 | |
Drives: 2010 Challenger R/T;2011 Mustang GT Join Date: Jan 2010
All good and well but looks like you are masking the "problem" of not needing a tune with your intake by adding this, changing that, removing a part there..... I would be frustrated as Hell as a customer having to assemble, disassemble, reassemble, add this, remove that....OMG. |
04-26-2010, 05:50 PM | #48 |
I am the Stig
Drives: Black w/ IOM stripe 1SS Join Date: Jan 2010
I think the moral of this story is this:
If you want to bolt it on and not worry... go with CAI, ADM, Haltech or the like If you want something that you can adjust and tweak by swapping pieces here and there and tuning etc, Vararam can provide a more "custom" application. I don't think these are comparable products aside from the fact they are both intake setups, they are different animals
2010 Camaro - 1SS, Black w/ Orange stripes
04-26-2010, 11:11 PM | #49 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
This isn't exactly right. As long as you have the tube section around the MAF the same diameter as the OEM tube and the MAF sits at the exact same depth, you should be good to go. This is assuming you don't have a lot of turbulence in the tube. The maf should correctly read the air going past it. Making a GOOD CAI utilizes this while improving on the OEM flow characteristics. My Halltech ran FT's that were almost identical to the OEM FT's, without a tune.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
04-26-2010, 11:54 PM | #50 | |
Drives: '10 Camaro SS Join Date: Apr 2009
2010, SIM, 2SS/RS, LS3, CGM Stripes
04-27-2010, 10:02 AM | #51 |
The VR was designed to be adjustable to suit many different combinations and HP levels.
This adjustability is a Bonus to our dealers/ tuners, allowing them to build or tune more aggresssivly for max Power/Torque with excellent drivability. If you don't want this then you just buy a no tune model and leave it alone. But nobody leaves a Camaro alone for long, which means at some point you will be tuning. The power a VR can generate on a stock or Modified car is far beyond the off the shelf hp gains of other intakes. Tuners have already proven what we saw on the flowbench long ago. It is more complex, because its designed to go far beyond where it is when you take it out of the box. The adjustment is there to allow the intake to grow as your power needs grow. Our customers/dealers/tuners like having the adjustablity. VR Tech |
04-27-2010, 11:56 AM | #52 | |
Get me my meds!
Drives: 2010 SS/RS M6 & solid black, baby! Join Date: Jun 2009
Swifty
Mods: ADM race CAI, Vector tune, ARH headers, Borla 'S' types, Revolution hood & chin, MGW short-shifter, T-Rex phantom grille
The legend continues... |
04-27-2010, 12:37 PM | #53 | |
Drives: 2010 2SS RS L99 Join Date: Oct 2008
04-27-2010, 12:38 PM | #54 | |
What we call MAF noise is and erratic signal caused by turbulence nothing more. Turbulence, Air NOT moving in a laminar flow, or in simple terms going crazy. You can't have a weak signal unless you have weak air flow across the sensor, and it can still be steady signal. Ted.
04-27-2010, 12:38 PM | #55 |
Drives: 85 Vette, 07 Escalade ESV, 03 GMC, Join Date: Nov 2009
".....Our customers/dealers/tuners like having the adjustablity."
Based on this post, people who only wants a "no tune" CAI solution, needs to remove your intakes from our lists of possible choices? There are numerous owners like myself who are eyeing a few simple mods: cat-backs, CAI...we are obviously looking for a the most gains for the buck without needing a tune for the next 5 years, your CAI is definitely not for us. Your infinite adjustments also preclude a lot of the weekend mechanics who would like to install a CAI themselves. When designing this intake, did you people uses any sort of CFD (Computational Fluids Dynamics) software to understand the airflows you are developing? Just curious.
ADM Performance installed and tuned: Maggie, Stainless Works Power LTs, ADM race cai, ADM ZL1 scoop Whiteside Customs Super Street 2 Package w/ coilovers BC Racing Coilovers and lowered, Whiteline Bushings & Swaybars MBRP catback exhaust, ZL1 bumper conversion, Drake billet shifter, Hurst paddles, NLP rear spoiler, OEM GFX, Vis Racing hood, ASA GT5 wheels |
04-27-2010, 12:45 PM | #56 | |
Get me my meds!
My impression is that it's a MAF placement problem. Even mine had minimal surging after installing it, but not eveyone has been that fortunate. Still, I decided not to take a chance on screwing my motor up long-term.
Similar Threads | ||||
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) | raptor | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 14 | 06-02-2020 12:51 PM |
DIY: Vararam CAI Install with Color Photos | Jeanius | Camaro DIY & HOW-TO instructions & discussions | 22 | 05-26-2015 02:48 PM |
