06-19-2015, 02:23 PM | #43 |
Drives: 2011 2SS Join Date: Jun 2013
Ya I get all that I just dont think its possible for the stock pulley on a ecs kit (3.47) to make 12 psi with the restrictor that comes with the kit. I dont care what combo you have on the camaro either its a gauge issue like you mentioned or some other variable that is not accurate if my information about the kit or correct then that is way high. The stock kit was designed for like 8 psi
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
06-19-2015, 03:05 PM | #44 |
Drives: 2011 RS 2SS Camaro Join Date: Apr 2014
Well then ECS boost gauge they use on their dyno is wrong I suppose
Or they sent me a different plate knowing my goals and what I had for mods |
06-19-2015, 03:08 PM | #45 |
your numbers support that much boost its just really high for the stock pulley combination the intent for the base kit with the restrictor in was to make like 8 pounds that pretty much any stock car could throw on with little supporting mods and enjoy.
06-19-2015, 03:51 PM | #46 |
Im 7.8 lower and 3.47 upper. 12psi unrestricted on stock cam and mild cam.
06-19-2015, 04:05 PM | #47 |
What u make bo is what I would expect from an Un restricted one but to make 12 with the same pulleys and restrictor still in doesn't seem right. By the way op I am in no way bashing u or what your saying just trying to understand how it could make 12 with the stock configuration and restrictor
06-19-2015, 04:22 PM | #48 |
I completely understand
06-19-2015, 04:26 PM | #49 |
Drives: 03 Cobra Join Date: Jun 2010
That is very impressive! Cant wait to see some track times!
2003 Cobra (Stock Motor/Boost Only)
640rwhp/ 550rwtq on 93... Well over 700rwhp on CORN |
06-19-2015, 06:33 PM | #50 |
Boost is a function of restriction and force.
