06-12-2016, 08:39 AM | #575 |
Drives: 2013 SW 2SS/RS/1LE Join Date: May 2010
Oh man...not cool.
06-12-2016, 10:43 AM | #576 | |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
This is happening more often than not. Because of the stuff they put in the gas. Rots anything rubber. I was replacing my fuel line once a year because of fuel rot. A couple of years ago I tried using a High Pressure fuel hose, you get at any auto parts stores. It has a small membrane for the I D, that does not break down with gasoline. I replaced all my fuel lines four years ago and they still look like new. It costs a little bit more than regular fuel line, but no more brittle fuel hoses. Last edited by Dimitrim; 06-12-2016 at 03:38 PM. |
06-12-2016, 03:13 PM | #577 | |
Account SNAFU
Drives: 13 Tahoe 79 Scout II 15 1LE Join Date: Sep 2008
Sent from my campfire using smoke signals |
06-12-2016, 11:08 PM | #578 | |
06-13-2016, 11:46 AM | #579 |
Drives: 2015 2LS Join Date: Mar 2016
Signed!
BTW, be careful taking the vehicle somewhere else for an evaluation that is not a certified GM shop. I had a car a few years ago that I paid to have a timing belt replaced on and the shop cross threaded the harmonic balancer bolt. After they repaired twice, new balancers and pulleys, the third time the crank was shot. Took it somewhere else for an evaluation before taking it to them the third time. Took written reports and pictures to court to explain their expert opinion that the first shop had cross threaded the balancer crank bolt. The shop's argument was that they felt the shop doing the evaluation had tampered with the crank trying to fix it and damaged it. They did not repair it, just evaluated it. Went to court and lost the case because I could not prove they had not tried to fix the car and in the end, cost me an engine from a salvage yard. |
06-15-2016, 07:19 PM | #580 | |
El Duderino
Bad things sometimes happen to good people, but I believe that for all your suffering, SOMETHING has to start going your way as far as your vehicles. Hoping for some good fortune to come your way soon. And for Sterling Auto Group?
I bowl. Drive around. The occasional acid flashback.
06-15-2016, 07:54 PM | #581 |
Drives: 2017 1LE SS Join Date: May 2014
I keep checking in on this thread hoping GM comes to their minds. Glad I'm not holding my breath. But I still hope it turns around
'If one day the speed kills me, don't cry. Because I was smiling.' - Paul Walker
06-15-2016, 08:15 PM | #582 |
Account SNAFU
It's currently got the oil pan off of it checking Rod bearings, which so far all seem to be good and tight.
06-16-2016, 07:53 AM | #583 | |
Drives: 2015 c7 Join Date: Nov 2009
I dont see a reason not to install one after warranty is over. I also dont see a problem with never installing one, and doing a manual clean every 40k miles depending how much you drive. |
06-16-2016, 06:10 PM | #584 |
Ed
Drives: 2015 camaro 1le 2ss Join Date: Apr 2016
With forty something pages, I might have missed it, but has the Gm customer assistance people that watch this site ever comment or asked op to call them??
06-16-2016, 08:24 PM | #585 | |
Account SNAFU
06-16-2016, 11:07 PM | #586 |
CamaroFans.com
I PM'd with them about it. This one was waaaayyyy over their heads.
06-17-2016, 04:59 AM | #587 |
Drives: 2013 1le 2ss rs black Join Date: Jun 2016
What if you used your cars insurance comprehensive coverage ?
Had a car when I worked at a gm dealer that the costumer drove in a water hole sucked in the intake and hydro locked the engine.( put a big hole in the block, sunfire.) That's what this costomer used to fix their car. |
06-17-2016, 06:47 AM | #588 | |
Drives: Love the one you're with Join Date: Sep 2009
