05-30-2014, 04:30 PM | #5937 | |
Drives: '14 Z51 3LT Stingray and '13 Cruze Join Date: Feb 2010
"We have a mental health problem disguised as a gun problem, and a tyranny problem disguised as a security problem."
"What is a moderate interpretation of the text? Halfway between what it really means and what you'd like it to mean?" -Antonin Scalia |
05-30-2014, 04:53 PM | #5938 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Honestly, I've only loaded a few hundred rounds. Most of that was for my Garand. I wasn't worried at all because I found the load in book specifically for Garands. They have all fired and ejected fine and are pretty accurate. I haven't had much time to do load development for my .30-06 bolt action yet but I will over summer. Just take your time and measure the powder charge carefully and then measure the length of your loaded round every so often. I found people shooting .30-06 with similar bullet weights and used their data as a starting point. Just reduce it by 10% and then do the ladder test to find the load that works for you. |
05-30-2014, 06:18 PM | #5939 |
Drives: 2010 Camaro 2LT RS, 2009 GTR Join Date: May 2009
Just finished my AR build from scratch. Just need to go shooting now. Weighs in at 7.4lbs but that's not on a postal scale so I'll need to double check the weight. And I put my XDS .45 (my carry pistol) and my CPX-2 9mm in the photo just cuz
Build thread: http://www.camaro5.com/forums/showthread.php?t=152335
Photos: www.flickr.com/bradbeer GTR Instagram: @NoCrustGTR |
05-30-2014, 07:18 PM | #5940 |
Drives: the 2nd amendment home Join Date: May 2008
Who is the MFG of the side cocking upper? I like your build
-- Benjamin Franklin lib·er·ty /ˈlibərdē/ noun 1. the state of being free within society from oppressive restrictions imposed by authority on one's way of life, behavior, or political views |
05-30-2014, 07:40 PM | #5941 |
Thanks!
Company out in Missouri called 2 Vet Arms (husband/wife combo of military vets) http://www.2vetsarms.com/ They make full rifles or you can get the upper/lower separate. Or just the upper like I did. Here is the actual upper http://www.2vetsarms.com/product-p/2va-15-recassy.htm
05-30-2014, 09:47 PM | #5942 | |
Drives: 2SS/RS Join Date: Sep 2008
06-02-2014, 08:48 AM | #5943 |
Has anyone painted a weapon with Duracoat or Cerakote? Opinions? Especially in high wear areas. I'm going to camo a 1911 and a rifle, maybe a shotgun as well.
06-02-2014, 11:33 AM | #5944 |
ΜΟΛΩΝ ΛΑΒΕ
Drives: 2010 VR/W 2SS/RS L99 Join Date: Dec 2012
I have my Barrett M95, Saiga 12, FAL and an old model 11 all cerakoted and there is some wear on the sliding surfaces but they're lube points anyway so I don't worry about it. It's good stuff since it doesn't peel and chemicals don't hurt it.
A note you should know though is if you do the barrel you should use air cure and not heat cure, the air cure has a higher temp rating for some reason.
06-02-2014, 04:15 PM | #5945 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
My wife and our new hobby
06-02-2014, 04:22 PM | #5946 |
Bayoucitymusclecars.com
06-02-2014, 04:27 PM | #5947 |
06-02-2014, 04:56 PM | #5948 | |
06-02-2014, 04:59 PM | #5949 |
Nice gun porn pics!
06-02-2014, 06:31 PM | #5950 |
COTW 5/06/2013
Yes they are, even had a couple of Ball players in there today we met.
Tags |
camaro gun |
Similar Threads | ||||
Firearms section? | monstertodd | Site Related Announcements / Suggestions / Feedback / Questions | 23 | 06-10-2010 08:32 PM |
Removing Swirl Marks using a Flex and Meguiars M105/M205 | Angelo@Autopia | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 5 | 05-22-2010 10:36 PM |
The COPO of Today | The_Blur | 5th Gen Camaro SS LS LT General Discussions | 48 | 01-31-2010 07:00 PM |
Laws Protecting Consumers for Aftermarket Parts | strauchpete | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 9 | 01-17-2010 08:31 AM |
IMPORTANT Part 1 Warranty Disputes | Zeus | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 11 | 08-25-2009 11:37 AM |
