03-25-2013, 08:58 PM | #603 | |
Drives: 2010 Camaro Join Date: Feb 2010
I asked him the day that link showed up and he said no bueno. |
03-25-2013, 09:42 PM | #604 |
Drives: 08' F250 Diesel & 10' Camaro 2SS Join Date: Nov 2010
I can't see how you have enough material on the housing to machine it to 108mm atleast on the Maggie.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets |
03-25-2013, 10:09 PM | #605 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
03-26-2013, 12:30 AM | #606 |
Drives: 10 LS3 2SSRS IOM,21 ZLE Wild Cherry Join Date: Aug 2009
105mm is maxed with RDS OEM type adapter plate. Inlet is bored to the outside edge of the origional gasket groove. So only 105mm truely available.... so only 3mm gain due to bottleneck. Whipple's could use it.
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . |
03-26-2013, 07:42 AM | #607 |
Drives: 2010 ZR1 Camaro Join Date: Dec 2012
03-26-2013, 02:15 PM | #608 |
Banned
Drives: gen5 Join Date: Mar 2013
03-26-2013, 02:26 PM | #609 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
03-26-2013, 02:36 PM | #610 |
Banned
04-13-2013, 11:09 PM | #611 |
Went to the track today. Went into reduced power mode again coming out of my burn out. Code was P2101. Is this the same code most of you get?
04-18-2013, 09:34 AM | #612 |
What happened to the fix for these? I sent Nick Williams an email, but haven't received a response. I don't want to go back to the track until mine is updated.
04-18-2013, 01:34 PM | #613 |
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
This is why I went with TPIS. you can never get ahold of Nick.
04-18-2013, 04:24 PM | #614 |
Post #533, not the same as all, but what I got. I had one of the 2nd version mods done and no problems so far at 707 RWHP at Mile-Hi elevation.
04-23-2013, 04:02 PM | #615 |
AquaRob
Drives: ABM RS\SS; 69 427 Camaro; 1970 Z28 Join Date: Mar 2010
I checked the TPiS website and they don't list anything for the 5th gen Camaro. Is there a part number for this TB?
Centerline, Weld, Holley, Nick Williams, GMPP, Diamond, ARP, Callies, Nelson Racing, Pro Torque, Strange, J&S Polishing, RMCR, AAC, MBRP, Flowmaster, FAST, Comp Cams, RX Performance, Aeroquip, Spectrum Powder-Coating, Current Performance, RX,TDub Racing, DSS, Fore Innovations, Aeroquip, Earl's, BMR, Ximpac, MPD,Street Scene, Blood, Sweat and Tears
04-23-2013, 04:33 PM | #616 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
Give them a call. It is not a camaro specific TB.
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
Tags |
boooo, oc2donefixed |
