10-28-2013, 12:22 PM | #6889 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Lmao. Good luck with that. Lol
10-28-2013, 01:08 PM | #6890 |
Drives: 2010 Camaro SS Join Date: Apr 2013
TSP 1 7/8 LT, ADM Race Cold Air w/ Race Scoop, GPI SS3 LS3 Cam, Powerbond UD, 3.91 Gears, GPI Posi Mod.
498RWHP/451RWTQ |
10-28-2013, 01:12 PM | #6891 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
The heck with the mods, I think this guy has the right idea!
Crap, the pic wouldn't load! He's a homeless guy holding a sign that says "I won't lie, I want BEER!" Edit: Here it is! Last edited by ssmike; 10-28-2013 at 01:17 PM. Reason: add pic |
10-28-2013, 01:16 PM | #6892 |
If it works for him it will work for me!
498RWHP/451RWTQ |
10-29-2013, 07:25 AM | #6893 |
So when going to a nitrous setup, what are some key things I need to do before doing the setup? Also what are the recommend plugs?
1 7/8" TSP headers straight piped, Custom Tick Performance cam w/ supporting mods, 1" BMR springs and other BMR suspension mods. Tuned with HPtuners by Matt@FSP
10-29-2013, 08:23 AM | #6894 |
V8 Lounge member #2
You'll need BR7EF which are ngk part # 3346
As long as you haven't changed compression. You'll need a bottle warmer, purge solenoid, window switch, and the LPE Lnc-2000 (?) it's their timing retarder and is plug and play.
10-29-2013, 08:32 AM | #6895 |
Let's go Rangers!
What to upgrade my sways to the Pfadt ZL series.
Is this something that is hard to do? I've done some research and it seems pretty straight forward, allthough the needed front endlink swap scares me a bit. I'd say my mechanic skills are a 6-7 out of 10. |
10-29-2013, 09:02 AM | #6896 |
BL1ZZRD
Front and rear?
10-29-2013, 09:07 AM | #6897 |
Let's go Rangers!
10-29-2013, 09:28 AM | #6898 |
BL1ZZRD
Rear is a piece of cake! You may need to remove the rear half of the exhaust if it's in the way. Depends on what aftermarket set-up you have. Not sure about NPP if you have that. To do the front bar however you will need to loosen the engine mounts and raise the engine about an inch in order to remove the stock bar and install the new one. The endlinks should be pretty easy to do front and back.
10-29-2013, 04:02 PM | #6899 |
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
I do not know why everyone says that you need to raise the engine to remove the front sway bar? I have removed and installed three sway bars and never touched the engine mounts. I guess I am pretty good at twisting and figuring out how to get $hit out and in. I am not saying it is easy and I recommend doing ti from the passenger side but it is possible.
nyrfan, GO BLACKHAWKS!!!, have you done any other upgrades to your rear? Specifically the half shafts/axles. Also, It is a whole lot easier if you drop at least one side of the exhaust. Do not let the endlinks scare you, they are pretty easy with the right tools. Follow the directions that Pfadt gives you and you are good to go. Any additional questions and give Tyler/Jordan at JDP a call or Matt/Name Escapes me at FSP a call for tips/questions. Or us since quite a few of us have done this swap already. Now, I need to head to the garage myself and figure out what is up with my brakes. T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
10-29-2013, 04:58 PM | #6900 |
Ok yeah I planned in getting all those things minus the plugs, wasn't sure which ones to get.
10-29-2013, 05:34 PM | #6901 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
10-29-2013, 05:51 PM | #6902 |
V8 Lounge member #2
Daz rye!!!' Put me in coach lol
Tags |
birm is awesome, buy from birm, buy from fsp, da hawks own da cup!!!!!, degenerate slugs, embrace the farmers tan, gpi ftw, is it stock?, ls7 build, rhino vvt cams, ricer v8s with k&ns |
