05-13-2015, 02:02 PM | #57 |
Drives: 2011 Camaro 1SS Join Date: Dec 2011
Don't get me wrong I masterbate to the ERL superdeck
05-13-2015, 02:15 PM | #58 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
05-13-2015, 02:24 PM | #59 | |
Cyber, I agree. If someone actually saw all the options in person, and rode in all of them, everyone would get the AGP kits.
Nick
Corvette Z06 -1200ish rwhp |
05-13-2015, 02:44 PM | #60 |
Drives: 2010 Camaro SS Join Date: Aug 2013
Does the OP want a roll-racer that can be driven daily or a daily driver that can do some roll-racing? I have an ECS kit that has a torque curve similar to the TT shown above. Up top, it is great. Everything to the left of 3500rpms...not so great (not really much better than stock). I have a friend with a KB on his cobra. That is the kind of low end grunt that makes a fun daily driver! It is still pretty quick at the strip too.
OP...be honest with yourself on what you really want. I spend 99% of my time to the left of 3500RPMs. For me, my existing setup is nice, but not optimal. I'd like to see the torque curve on one of these Heartbeat setups! |
05-13-2015, 02:48 PM | #61 | |
Drives: 2010 Camaro SS Join Date: Dec 2006
So in the end, there is roughly 100-150 horse being gobbled up by that belt drive. I still love my Kenne Bell...but turbos are awesome units as well and clearly wear the crown for high HP/TQ marks on the dyno graph. Lots of cool options!!!! |
05-13-2015, 03:00 PM | #62 |
It's not a DD, the cam in it now is the JRE rough idle blower cam
05-13-2015, 03:02 PM | #63 |
I'm not too concerned with much of what happens to the left of 3500 rpm
05-13-2015, 03:10 PM | #64 |
I just don't get people flooring it all the time. If you want to go fast downshift. If you aren't WOT below 3500 then you always have more on tap by just adding more throttle.
Nick
05-13-2015, 03:44 PM | #65 |
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Twins belong on 5th gens. I would use them but not switching my setup now unless I find a money tree plus I like my centri. When it comes to PD's I just say no.
05-13-2015, 05:34 PM | #66 |
Drives: 2014 camaro 2ss Join Date: Apr 2015
Like I said before TT has a lot of advantages. If I had the means to go really big I would definitely go agp and probably do a stroker while adding some forged internals to make a HP monster.
Yes you can make turbo setups that "out torque" a pd blower by not using turbos too large. But even then the torque curve often has a major peak then power falls of quickly. Taking the dyno posted by cyber predator as example,Peaking at 708 at 4.5k rpm. Just 1k rpm lower at 3.5k there is almost a loss of 200 ft/lb. At 6k rpm its already lost 100 ft/lb. That is not a big powerband to work with. Compare that with most pd blowers where you rarely loose more than 50-70 ft/lbs from peak through out the entirety of the rpm range. Where ever you shift you will be in the power. There are lots of advantages to Centri's, and TT that aren't being discussed here such as IATs and weight distribution. But in regards to the OP wants of a 700 rwhp street machine/roll racer, those just blatantly disregarding a pd's usefulness at this task aren't doing the OP any favors. |
05-13-2015, 05:36 PM | #67 |
Thanks for that perspective davison
05-13-2015, 05:38 PM | #68 |
So how do you feel about a nice centri setup that gets more powerful as rpm climbs
05-13-2015, 06:10 PM | #69 | |
Drives: All things Turbocharged Join Date: Dec 2010
05-13-2015, 06:30 PM | #70 | |
Drives: 2010 IOM SS Join Date: Aug 2009
