#57 |
![]() Drives: 2010 Camaro SS,2008 Hayabusa Join Date: Jun 2010
Yeah but he also has ported and polished heads
#58 |
Drives: 2010 2SS RS Black on Black Manual 6 Join Date: Sep 2009
Taken from http://boostzilla.com/store/allzilla/faq/supercharger
How much horsepower will a supercharger add to my engine? Although some manufacturers claim a specific horsepower increase, superchargers actually add horsepower as a percentage gain (percentage of an atmosphere). After adjusting for thermal and mechanical energy transfer, if an efficient centrifugal supercharger is generating ~5.5-6.5 psi (just under 1/2 an atmosphere), you will see around a 35-50% gain in horsepower and 35-50% gain in torque at your non-supercharged maximum horsepower rpm. At higher boost levels, the heat generated by compressing air will produce diminishing returns as the boost is increased, although the use of intercooling or racing fuel can avoid this scenario of diminishing returns. Assuming the use of intercooling to run higher boost levels while maintaining reliability, a 50-70% increase can generally be achieved at around 7 psi on an engine with 11:1 compression running pump gas. The gains in horsepower and torque delivered by each BOOSTZILLA™ system can be found on the "Spec Page" for each kit within this site. |
#59 |
![]() ![]() ![]() ![]() Drives: 08' F250 Diesel & 10' Camaro 2SS Join Date: Nov 2010
Every link you have shown is 9-10psi not 6.5 and they are all running meth on top of 10psi
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets |
#60 |
Table math revisited.
Assuming 480RWHP... headers, cam, exhaust, tune... (baseline of 370) 35% 648 40% 672 45% 696 50% 720. So again, please explain to me why my 664 rwhp, is impossible? Just trying to understand.. at least im arguing with numbers to work with... and information... |
#61 | |
![]() ![]() ![]() ![]() Drives: 2010 IOM SS Join Date: Aug 2009
Is this Calbert? Are you brothers? If not somethings wrong with that Canadian air. Another D1 Procharger thread. So at 10 Psi you'll make 1000 Hp just like Calbert. Do you 2 use the same shop. He has outrageous claims also. |
#62 |
#63 |
Heres what I find interesting..
NO one is correcting my napkin math.. Just talking.. Talk talk talk talk talk talk talk talk talk. BACK YOUR SHIT UP? nyny69 , I know Chris on the forums, we both goto the same place for performance but beyond that no, I don't directly know the individual. |
#64 |
If you go to post 10 he tells you he also has ported and polished heads. This means more then all his other mods put together.
#65 |
I'll respond when we can focus on the 'math' since that seems to be holding its ground pretty well..
#66 | |
BTW, why the hate for Jannetty. |
#67 | |
So now just because someone posted it its true? WTF dude
#68 |
Ok so is the consensus then that there is no way I am capable of 665 rwhp, my napkin math is wrong (somewhere?) and the guys at booststill are out to lunch? Headers with tune 40ish horsepower Aggressive CAm often custom grind.... 60+ horsepower Exhaust 10 horsepower baseline 370. Thats like 485ish rwhp.. 35% - 50% is all based on temperature humiity **** it, you guys can't argue the #'s so we default to splitting hairs. Bunch of pathetic sore losers. Get with the program, run the numbers, accept reality and move on. Procharger all the ****ing way. |
#69 | |
#70 |
Can you please provide your 'math' on how you came to that conclusion.
I think you need to repeat gradeschool. Somewhere along the way you skipped out on math. According to Boostzilla supercharger writeup its between 35 and 50% of your currently exhisting RWHP. So 370 + 40 = 410 410 + 60 = 470 470 + 10 = 480 So 35% on top of 480 is just shy of 650 40% of 480 is just shy of 675 Stupid kid. |
