11-12-2021, 12:21 PM | #57 |
11-12-2021, 01:05 PM | #58 | |
Drives: 2011 Camaro SS Join Date: Jul 2019
https://www.camaro5.com/forums/attac...1&d=1636743895
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
11-12-2021, 02:13 PM | #59 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
11-12-2021, 03:31 PM | #60 | |
#teamGPI
Drives: 2010 Camaro SS Join Date: Aug 2020
11-12-2021, 04:31 PM | #61 |
Drives: Car Join Date: Jan 2013
If it helps, here’s Vengeance's cam parts on my car.
Vengeance Racing Custom Camshaft - Kaotik Vengeance Racing Hardened Pushrods Vengeance Racing .660 Lift Dual Spring Kit with TS Retainers Trunion Kit for Stock Rockers Melling Hi Volume Oil Pump for LS Engines C5R Timing Chain 3 Bolt Conversion Timing Gear- MUST specify 4 Bar or Half Moon LS2 Dogbone Timing Damper ARP Cam Bolts GM Crank Bolt GM Front Cover Seal GM Front Cover Gasket GM Waterpump Gaskets Powerbond 25% Underdrive Pulley with Gates Belts 160 Degree thermostat LS2, LS3, LS7 Vengeance Racing Valve Cover Breather NGK TR55 Spark Plugs-#3951- Set of 8 GMPP Performance Plug Wires for LS2/3 |
11-12-2021, 05:44 PM | #62 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
My reget in getting my cam was not getting the bigger 1 the first time and having to buy it twice lol
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
11-12-2021, 06:10 PM | #63 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
No regrets . In fact I’d probably regret it if I didn’t do it . Cars are boring without them, or modded . Actually makes it more fun for me to see what I’ve done after installing my parts that I choose .that’s pretty much my fault though , street bikes ruined excitement for me lol
I have Sierra Denali fbo - stage 3 vvt cam going on 4 years now . Only hiccup I had was choosing a bad trunnion company the first time around .(lesson learned) don’t use trunnions that are cheap . Go with smith brothers or Che . Looking back , I originally chose a cam that wasn’t gonna “require” a torque converter . Even though it doesn’t require one and you could manage it , a torque converter was the way to go .. So if I just included a torque converter originally in my build I could of went with a bigger cam and I’d probably wouldn’t have left anything on the table . It’s fine though, it’s my DD work truck . Why I got the zl1 and going max effort . |
11-12-2021, 11:31 PM | #64 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
The 10296 is a high volume / pressure pump that is 10% over stock. Lot's of people prefer them, I have the 10355HV which is 20% of more volume over stock. Either one of these pumps will give you more idle pressure and higher pressure across the board.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
11-12-2021, 11:40 PM | #65 |
I used to have to do that also, but here of lately my engine has for some reason seemed to have calmed down. It doesn't really jerk in gear anymore or push through the brakes.
11-13-2021, 06:52 PM | #66 |
Thanks Joe.
11-13-2021, 07:34 PM | #67 |
#teamGPI
Really? That's odd that it lessened over time, I do plan on a converter in the near future though, thinkin a circle d 3800.
11-14-2021, 08:32 AM | #68 |
You are welcome..
11-14-2021, 08:36 AM | #69 |
Well can't say that it is a bad thing, I never asked anyone. I have been doing it since the car was brand new and stock. I have always done this. Just seems to be a good thing to do to save wear and tear on the parts.
11-14-2021, 08:40 AM | #70 |
Wow that's weird. Never heard of that happening before.
